587,203 active members*
3,161 visitors online*
    Apr 2012
    91
    Question 3D tool change
    Running a simple 3D file using roughing and finishing cycles. Estlcam post processing to PlanetCNC.
    At the tool change I cannot make the change, or zero the new tool, because the jogging is locked. I have to stop the programme. Change and zero the tool and then restart the programme from the gcode tool change line.
    Is there a better way to do this when using a simple collet chuck please?
    Mar 2017
    1328
    Re: 3D tool change
    Do you use PlanetCNC TNG software?
    You would need to edit M6 script code in order to have correct tool change motion sequences.
    You can find example file of M6 script in installation folder of TNG: Samples/Templates/Scripts -> M6_measure.gcode
    You would need to include copy of configured M6 script file to your profiles Script folder.
    Apr 2012
    91
    Re: 3D tool change
    Can you elaborate on this please. I do not understand how to do this?
  1. Change time delay in tool change program
    By bspear in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2018, 04:01 PM
  2. Replies: 6
    Last Post: 05-10-2016, 12:30 AM
  3. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  4. How do I change the Tool Change Position?
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 01-04-2014, 08:08 PM
  5. change Z position of the spindle in tool change
    By michael-p in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2011, 09:18 PM
