603,796 active members*
4,741 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Spindle drop from Z Home for tool change, is there a way to change distance?
Results 1 to 7 of 7
    Feb 2014
    72
    I'm guessing the drop is for the Auto tool changer but I just have the PDB. The reason I need it to drop less or not at all is clearance from tool to material. Sometimes I have large drill bits or milling a pocket at the end of a large part (hole on and of 11.25" block in a vice with less than 0.100" clearance). I'm now moving too off part and manually inserting z height into G-code after tool change to bring it back up.
    Is there a file that defines this drop height I can change?
    Jan 2012
    58
    Re: Spindle drop from Z Home for tool change, is there a way to change distance?
    Not sure from your description, but you may be referring to your G30 setting.... When you press the "Go To G30" button (lower right corner of PathPilot screen) does your Z axis home to this position? If so, you can set the G30 position using the button in your Offsets window... Hope this helps. Gerry
    Sent from my iPad using Tapatalk
    Nov 2010
    291
    If mach3 go to the settings tab and change your tool change location to Z0. That will run Z up to machine home.
    Mach3 toll change position on my machine is set to -3. in the z. not sure where PP has anything set.
    Feb 2014
    72
    For reference, I'm using Pathpilot. I'll definitely check the G30 tonight and see if that's the right thing.
    Luv2ride, sounds like its pretty simple in Mach3 but PP definitely takes away a lot of buttons for tuning.
    Nov 2010
    291
    Do you write your own code? You could omit the M998 and just use G53 Z0. and M0. Put your height offset in the following line or between the two here and the Z would go home and mandatory stop for the tool change.
    Feb 2014
    72
    Just to loop back around on this, The "Set G30" works perfect.
    Before F360 tool change would go to top with coolant still spraying and spindle spinning, then hit start and it drops 2" for a tool change (maybe I caused it at some point hitting Set G30 when I was figuring things out). Now it goes straight up to top and spindle/coolant stops for tool change.
    Thanks guys!
    Jul 2004
    1424
    Could be worse... I must have accidentally hit the "set G30" button with a endmill holder in the spindle, and the next time I did a tool change with a drill chuck installed I barely hit e-stop in time to prevent a crash as it drove toward the table...
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  1. New Home for Tool Change
    By tcovington in forum Haas Mills
    Last Post: 05-03-2016, 03:03 AM
  2. Head drop during tool change Fanuc 0MC
    By manitoba_farmer in forum Fanuc
    Last Post: 01-05-2014, 03:40 PM
  3. Replies: 6
    Last Post: 01-22-2013, 08:03 PM
  4. VMC1000 Tool change arm not returning to home
    By KevinV_MEI in forum Bridgeport / Hardinge Mills
    Last Post: 10-03-2011, 05:43 PM
  5. How to stop table from returning home every tool change
    By david martin in forum Mastercam
    Last Post: 06-21-2011, 12:43 PM
