587,879 active members*
3,971 visitors online*
Page 1 of 2 12
Results 1 to 20 of 32
    Jan 2012
    47
    4th axis machining losing steps
    I have a project in stainless 303 based on a 3 inch length of 5/8 round stock.
    It has some features such as holes and a flat surfaces in the first inch or so, the rest is pretty much a complex contour cut. So after rough waterlines repeated 90 degrees apart all around the piece, and some drilling operations I use rotary machining with a 3/16 ball mill with a 5% step-over basically using the 4th axis in as much of a continuous turn as the individual z axis step allow as the ball mill traces a spiral path around the part. This step takes about an hour and the 4th axis rotates past 0 degrees about 250 times. The finish is great, but there seems to be a very small cumulative rotational error that, by the time the features are under the ball mill , has progressed to almost 30 degrees.
    Would the Tormach homing device, cure that error by telling Mach3 where 0 degrees is at every rotation?
    Interestingly if I tell the 4th axis to return to 0 at the highest speed it is capable of turning from the end of the run, it thinks 0 is actually the rotational error. To me that means the error is somehow tied in to Mach 3 handling of the G code.
    any ideas?
    Jun 2006
    2512
    Are your CAM coordinates set for incremental or absolute.
    Phil
    Jan 2012
    47
    I believe they are set by G90, so absolute, but I'll double check.
    thanks
    Mar 2008
    216
    Quote Originally Posted by KrausMotor View Post
    I doubt that your rotary axis is actually loosing steps. You should first check
    the rotary table coupling to ensure that it is tight and not slipping. If that is
    not the problem simply perform an MDI input of "G0 A90000" and wait for the
    rotary table to complete the positioning. If it stopped exactly on zero on your
    rotary table you will have confirmed that Mach 3 can handle 250*360 degrees
    of rotation (note that is really an excessive number of degrees, for reasons I
    will explain below). If the above test passes perform an MDI input of "G0 A0"
    and again check to see if the table stops at exactly zero after rotating in the
    reverse direction. It is entirely possible that Mach cannot correctly handle any
    rotations that large in an accurate manner. Note that 250*360 degrees would
    result in 180 million microsteps taken in the same direction on a rotary table.
    The Tormach rotary table homing sensor is unlikely to help you at all since it
    is only used when initially homing the table; it is not used during any actual
    machining moves.
    If you cannot constrain the machining to reverse every 360 degrees or so,
    another alternative that you could try is have the Post wrap 360 to zero and
    then position the rotary table back to zero after every wrap. This prevents
    the commanded angles from getting very large, although it would obviously
    slow down the machining while waiting for the table to "unwind".
    250*360 is an excessive number of degrees since any operations performed
    run the risk of returning a reduced precision. For example, the tangent of an
    angle (say 3.7 degrees) computed in single precision has a certain amount of
    error in the result. If I add 250*360 to that 3.7 degrees and then compute
    the tangent of that the error could potentially be increased by a factor of
    250 because we are effectively asking for a factor of 250 lower error for the
    result to be off by the same amount. This is in inherent accuracy problem
    with floating point precision, so you should always try to avoid angles larger
    than a few times 360 degrees.
    I do not understant what you mean by "it thinks 0 is actually the rotational error".
    Mar 2008
    216
    Oops, my example error amount is incorrect. I was first assuming that the
    starting angle was 360, but I changed that the 3.7 degrees to reduce the
    potential confusion. As a result the actual error amount would be computed
    as (250*360+3.7) / 3.7, which is a potential error of 24325 times larger. In
    actual practice steps are generally taken so that the error does not get
    magnified by this much. This still remains a simplified example of why, in
    general, you should do to try to avout dealing with really large angles.
    Jan 2012
    47
    I do not understant what you mean by "it thinks 0 is actually the rotational error".[/QUOTE]
    What I meant is exactly what you say I should do to test the rotary table. At the end of it's run ( with it's 30 degrees of error) I typed a G0 A0, which should have brought back the table to 0 ( if by some miracle the error gets unwound so to speak) or an augmented compound rotational error, but the table stopped after the correct amount of degrees (90000) or 360*250 turns with the same 30 degree error. That tells me that it is able maintain accuracy even after 250 rotations, when only the A axis is involved.
    I think something is amiss in the Mach3 handling of the g code with multiple axis and very small rotational steps.
    cheers
    Mar 2008
    216
    cheers
    OK, based on what you have said thus far we cannot yet blame Mach3 since
    there were machining loads on the rotary table. Have you checked the motor
    coupler to ensure that it is tightly clamped? You can get 30 degrees of error
    if the coupler slips during a large machining load. If the coupler checks out
    perform the two MDI example steps that I suggested without performing any
    machining. With the coupler tight and no machining loads on the rotary table
    you can test how well Mach3 handles 250 continuous rotations in both of the
    directions.
    Without doing both of the above we cannot unambiguously determine what
    caused the positioning error. I would try 250 rotations on my rotary table to
    see if Mach3 handles that, except for two problems. My rotary table is very
    different from what Tormach sells (it generates around 2X the rotary force),
    and my PCNC 1100 is currently nonoperational since I am quite literally in the
    middle of the 3-phase stepper upgrade.
    Jan 2012
    47
    Ok, I've performed the two steps you suggested, 250 rotations to A 90000 and then back to 0. both performed excellently, the rotary table always ending on exactly 0 degrees as well as I can determine by eye. Except for the stepper motor getting quite hot there seems to be no fault with the rotary table as
    I have also checked the coupling and it is tight and does not slip.
    now what?
    Jan 2012
    789
    It could be worth contacting Tormach and see if they have encountered this.
    Mar 2008
    216
    Ok, I've performed the two steps you suggested ... now what?
    I had actually typed the "likely problem" if all of the above had worked, over
    2.5 hours ago. But when I clicked on the "preview" button just before I was
    going to do a “submit”, CNCzone suddenly decided to take me to a strange
    page while also discarding my entire text of several paragraphs. This second
    attempt will be a bit briefer.
    Since the mechanics and Mach3 correctly handle those large rotations, I have
    Some more questions - but I will also presume the answers and describe what
    is most likely to be happening in your situation.
    I particular, the below statement from you caught my attention, and it directly
    relates to something that I previously pointed out.
    My questions are: How many rotationsl steps are there in your 90,000
    degrees of machining, and what sizes are those rotational steps?
    I don’t know if Mach3 uses single, double or double extended precision
    floating point (all three are available in X86 CPUs – I used to be a CPU
    architect years ago). I am assuming that Mach3 uses single precision
    floating point for this analysis. It is a reasonable assumption since even
    with 0.1 mil resolution that still allows for about 140 feet of linear travel
    on any of the X,Y,Z axes. Note that for the below analysis I am totally
    ignoring the mechanical accuracy; I'm only considering the floating point
    accuracy.
    Single precision floating point has a best case resolution of 1 part in 16,777,215.
    Hence, when a rotary table is positioned at 1 degree, the smallest numerically
    exact step that it can take is about 5.9604648328e-8 degrees. What this means
    is that if you could command the rotary table to take the smallest exact size at
    1,0 degrees, the floating point result would be exactly correct. What happens
    if we command the table to move by 7e-8 degrees? Internally (inside Mach3)
    it numerically moves by about 5.9604648328e-8 degrees since that is just the
    closest floating point value that it can represent. The movement error is fully
    insignificant with a single step.
    When a rotary table is positioned at 360 degrees the smallest possible exact
    step size now becomes about 2.1457673398e-5 degrees. This is unsurprisingly
    360 times larger (coarser) than it was at 1.0 degrees.
    When a rotary table is positioned at 90,000 degrees the smallest possible exact
    step size now becomes about 0.0053644183495… degrees. This is 90,000 times
    What all of this means is that as the rotary table winds up from 0.0 degrees to
    90,000 degrees each step that it can precisely take becomes larger and larger.
    If you ever command the table to rotate by a large sequence of incremental
    steps and any of those steps is not an exact integer multiple of the available
    resolution at that degree setting, the actual movement would get rounded
    to the nearest numeric value that the floating point can represent. Hence,
    each movement is ever so slightly inaccurate and accumulating enough of
    these can cause problems.
    As a simple example, multiplying 0.00048828125 degrees by 184320000 steps
    results in exactly 90,000 degrees. However, starting at 0.0 degrees and then
    adding 0.00048828125 degrees together 184,320,000 times literally cannot
    sum up to the same exact 90,000 degrees because at some point (near 8192
    degrees in this example) the floating point step size cannot be accurately
    added since it is not exactly representable.
    The above is not really a Mach3 problem, even if it is using single precision.
    It is an inherent problem with floating point precision and a misapplication.
    For comparison, would anyone expect the same rotational resolution when
    the rotary table was positioned at 1.0 degrees and a billion billion degrees?
    If so, it would require a floating point representation that had more than 25
    decimal digits of precision. In contrast, single precision floating point has
    about 7.22 decimal digits of precision, which is more than enough for any
    milling machine with 0.1 mil resolution.
    Commanding a rotary table to move to 90,000 degrees by using a very large
    number of very tiny steps while expecting the same accuracy at when it is
    at 1 degree is comparable to having a milling machine with 0.1 mil resolution
    with X,Y,Z travels that are about 26 million billion miles long. It simple is not
    a reasonable thing to do.
    The fix for this is to have the CAM package be aware that the rotary table is
    constrained to 360 degrees (or a small multiple of that) so that a reasonable
    (winding and unwinding) tool path gets generated.
    Jan 2012
    47
    Quote Originally Posted by tbaker2500 View Post
    Absolutely! But these things always happen on weekends...
    cheers
    Jan 2012
    47
    Quote Originally Posted by Zetopan View Post
    I had actually typed the "likely problem" if all of the above had worked, over....(or a small multiple of that) so that a reasonable
    Yes that seems a likely assumption. I am using G code generated by Sprutcam using rotary machining technology with a spiral step and very small stepover to achieve a good finish. It seemed to be the right thing to do, but not very efficient time wise or result wise. I'll have to reconsider my machining strategy.
    There are many ways to skin a cat
    cheers
    Dec 2012
    59
    I would, honestly, like to see the full writeup. It's really fascinating stuff.
    I do wonder, though, about the Tormach 4th axis. I've used mine less then I would have thought, but in my limited experience, doing really tiny parts, I grew concerned about the amount of backlash that is inevitable in it's design. If I understand things correctly the table drive experiences backlash just like a traditional lead screw/nut, so each change of direction will experience some amount of rotation before it 'engages' again. I've never taken one of these tables apart, so I may be mistaken and backlash in the context of one of these tables may be a more subtle beast. I think I'm right, though.
    Tormachs suggested settings will result in either 30 to 60 arc seconds of lost motion (according to the manual), the difference being the looser fit will prolong drive life. That translates into .0008 to .016 degrees of error every direction change. I'm not sure which is the greater issue over a long program; very large angular values causing decreased precision or lost motion from repeated direction reversals. 250 reversals would result in about 4 degrees of error if you use the looser backlash setting. Probably enough to cause problems in a lot of work.
    The 'fix' might be to break the program up into some smaller sections, and rehome a couple of times throughout the program. That is assuming that the table is working 'correctly', and not experiencing some other sort of mechanical issue.
    Jan 2012
    789
    Quote Originally Posted by Moggot View Post
    I don't have one of these, so I can't speak from authority. But it sounds to me like you are describing .0008 to .016 degrees of slop when changing directions. This is not lost steps, and not cumulative. The motor is moving correctly each time, but it has to take out the slop in the gear train.
    Mar 2008
    216
    Rotary table backlash is NOT accumulative. If you have reversed the rotary
    table direction and lost 40 arc seconds of motion, then on the next reversal
    you will be back to your original zero arc seconds of lost motion, AFTER you
    move at least 40 arc seconds in the new direction.
    All even reversals takes you back to zero arc seconds of lost motion and all
    odd reversals result in a small amount of lost motion (40 arc seconds in this
    example).
    Jun 2006
    2512
    Surely the sumation error tends to zerror for a large number of random length steps.
    MACH works on floating point double precision.
    Phil
    PS: If you take absolute steps rather than incremental doesn't the issue goes away in any case.
  17. #17
    Jun 2006
    2512
    Could the error not also originate in the CAM application. What CAM are you using. After all it's the CAM that does the number crunching, MACH just does what it's told.
    Phil
    any ideas?
  18. #18
    Jan 2012
    47
    [QUOTE=philbur;1232642]Could the error not also originate in the CAM application. What CAM are you using. After all it's the CAM that does the number crunching, MACH just does what it's told.
    I talked to Tormach and Eric suggested I turn off toolpath viewing in Mach3 to allow the software to completely dedicate itself to the program steps. That didn't work.
    The backlash on the rotary table is adjusted correctly, I tripple checked.
    I'm using Sprutcam and chose rotary machining with a spiral machining path, a 10 percent tool offset from the y axis zero, which stays pretty much fixed during machining. I use a 3/16 ball mill and the spiral stepover is 5 percent to achieve a nice finish. The piece has been rough waterline milled in four quadrants, so the 3/16 ball mill has only about .010 to cut and offers minimal resistance to the rotary table. I noticed that on the section part where the profile is the same all around it, the rotation is only in one direction, but when the profile contains separate features radially, the table turns back and forth.
    I'm starting to think the steps are too small to be resolved accurately.
    I eventually solved the problem of machining the part, by redesigning it so that I could cut features at predetermined rotational positions, using the rotary as a fixed work piece fixture, and after having done the rotary machining only to the part where positional error in the A axis is irrelevant.
    cheers
  19. #19
    Jan 2013
    263
    That's a work-around but doesn't identify the real problem. I'd love to know where the issue was and if it's a mechanical limitation, software limitation, or just a misconfiguration. Is there anyone here actually use the rotary table live while machining with good results?
  20. #20
    Dec 2003
    673
    I had my new 4th axis slip when under load. I took the coupler off and reinstalled/locktited..
Page 1 of 2 12
  1. 770 losing steps on the z axis
    By concombrefrais in forum Tormach Personal CNC Mill
    Last Post: 03-22-2011, 06:40 AM
  2. Z axis losing steps
    By binfordw in forum Benchtop Machines
    Last Post: 12-24-2010, 01:19 AM
  3. Losing steps in Z axis!!
    By Westozy in forum DNC Problems and Solutions
    Last Post: 12-15-2009, 09:35 PM
  4. Losing steps with the Y axis
    By norman roy in forum Tormach Personal CNC Mill
    Last Post: 12-23-2008, 03:29 AM
  5. Y Axis keeps losing Steps
    By Normsthename in forum DIY CNC Router Table Machines
    Last Post: 11-06-2006, 12:26 AM
