603,370 active members*
3,765 visitors online*
    Apr 2025
    4th axis problems
    I have a Quaser MV184 E with a 4th axis chuck. I have tried to machine a cube from a round bar, but, I get 2 diffrent measurments around the cube. I have tried to recalibrate our tool, remeasure our workoffset for the 4th axis and now I dont know what to do. I havent had much experince with a 4th axis before so im kinda new to that area. How do we get this from not happening or do anyone know the best way to set the workoffset for a 4th axis that goes thru the X axis?
    Apr 2004
    5948
    Re: 4th axis problems
    Are you talking about a rotary axis parallel to X? Mine is set up that way, and I set the zero point for Y and Z at the center of rotation, and X as far to the left as possible. Touching off to a precision-ground cylinder with a known diameter helps to figure out the correct offsets.
    Andrew Werby
    Website
  1. 4th axis problems with mach 3
    By mushy75 in forum Mach Software (ArtSoft software)
    Last Post: 11-06-2015, 10:29 PM
  2. 4th axis problems
    By tjd10684 in forum Visual Mill
    Last Post: 04-21-2011, 01:26 PM
  3. 4th Axis Problems
    By Syncrude in forum Fadal
    Last Post: 07-09-2007, 03:02 PM
  4. 4th axis problems II
    By little bubba in forum Fadal
    Last Post: 10-24-2005, 01:13 PM
