OK so I just got a plasma cutter and never did anything but hand cutting until now and need a little guidance.
I'm using the 4th Axis on my CNC mill with a holder for my plasma torch to do some tube coping on some 3/8" Wall 4" Stainless tube. I cover the mill with welding blankets to protect it from the sparks. I'm using an Everlast Power Plasma 50, 50 AMP NON-High Frequency Start Plasma Cutter. The manual is useless and doesn't mention speeds and amps for cutting, I mean it doesn't mention anything to at least give me an idea of where to start. One person told me on an Everlast forum that the stand off should be 1/8" for CNC and my friends who have a CNC plasma run at 20 IPM for 3/8" thick material, but almost everyone else in the plasma world pierces at that height and then cuts at 1/16". So I set my PSI at 60, cut height at 1/16" [didn't need to pierce], 50 amps and 20 IPM on my CNC.
It cut like butter and seemed to come out pretty good. So my questions are I got a ton of splatter slag inside the tube. Is this much, refer to the pictures, or do I have it cutting with too much power (50 amps). What can I do to not have all that splatter slag as the parts are machined ahead of time? I figure I can do two things, spray the inside with MIG splatter shield spray and I could also make a circular aluminum insert that is held stationary while the part rotates in the 4th axis, with a notch in the shield at the top for the plasma to go through but not spray the tube itself?
Also the tube miter came out good but since the plasma cutter is stationary it, obviously, didn't bevel the sides of the tube miter. Think of mitering a tube with a hole saw. The saw goes straight down and cut the right and left side of the tube as it goes down, but when mitering on the 4th axis the cutter remains perpendicular to the workpiece as the workpiece rotataes so the sides don't bevel in. So when setting the tube miter on the corresponding tube is sits proud. I could just grind and hand fit it, but it would be nice to do all one operation and have it come out perfect.
Any help would be appreciated. Thanks.
