I currently have Version 4.3 and am evaluating version 5, but having some problems. I am a sculptor and design objects in Rhino and rough them out using a computer controlled wood router. Many of my objects are bowls, vases, or vessels. For some designs, I need to bore multiple holes (sometimes hundreds) perpendicular to and distributed over the surface of the object. As a test, I have been playing with the attached test object, with little success. I have tried using an elipsoidal drive surface with mixed results using 5 axis planar, and no success using 5 axis z level finishing.
1. Could someone suggest a work flow that will work with similar objects with multiple bores perpendicular to the exterior (or possibly interior) surfaces? An actual example would be great.
2. Is it possible to use 2.5 commands such as pocketing, profiling, and curve milling in 5 axis continuous mode? If not, will this be an enhancement in the future?
3. The 5 axis continuous roughing mode does not seem to recognize the control surface options such as "extend to box". Will 5 axis continuous roughing accept a user generated stock model? (I have not tried this approach yet)
Thanks for any help on the above questions.
Jerry
