587,181 active members*
4,121 visitors online*
    Sep 2005
    221
    Absolute encoders?
    Can anyone tell me what I have to do to switch a system over to absolute
    encoders, and how do they work?
    Thanks!
    Dec 2003
    24223
    A typical absolute encoder will output a 10 or 12 bit wide bit pattern in either true binary or gray code, if your system only accepts quadrature, then these cannot be used.
    Some systems however use a method of battery back up of the quadrature signal, but again, this is system dependant.
    If you go to a web site like BEI that offer absolute encoders, they should have a detailed explanation.
    Al.
    Albert E.
  1. Absolute or Incremental
    By mikede in forum Haas Mills
    Last Post: 02-04-2007, 12:02 AM
  2. MasterCam post with G2 absolute I J
    By Karl_T in forum CamSoft Products
    Last Post: 11-23-2006, 05:07 PM
  3. x/y absolute dimensions (how?)
    By corpse in forum Solidworks
    Last Post: 02-03-2006, 06:31 PM
  4. Absolute encoders?
    By murphy625 in forum CamSoft Products
    Last Post: 03-29-2005, 04:18 AM
  5. Absolute and Incremental
    By ACME in forum G-Code Programing
    Last Post: 09-04-2004, 11:45 PM
