587,201 active members*
2,883 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Added Some Light to the PCNC1100 Enclosure
Results 1 to 10 of 10
    Oct 2010
    670
    Can you say, "let there be LIGHT"!!!! BTW - the globes are impact resistant - from Rockler Tool
    Attachment 383434Attachment 383436Attachment 383438
    Attachment 383440Attachment 383442Attachment 383444
    Will be posting more on my Instagram (coolcncstuff_) once I get time. Have done a new coolant upgrade that I've not seen done before. But first I have to seal the inside of the new enclosure.
    Later,
    Awall
    The Body Armor Dude - Andrew
    Nov 2011
    26
    Re: Added Some Light to the PCNC1100 Enclosure
    Quote Originally Posted by smokediver576 View Post
    Later,
    Awall
    Very Nice..
    Mar 2015
    178
    Thats awesome
    Can never have enough light!
    I'm curious what frequency are they, current draw and cost ea??
    To date the brightest/ most lumens I've found (that fit without mods) are the old style "squiggly" 5K daylight 100 watt equivalent cfl's.
    They draw about 22 watts which is not great but way better than incandesants.
    100 watt 5K led's are almost as bright, run cooler and draw only 14 watts.
    Oct 2010
    670
    Quote Originally Posted by Paul-JB View Post
    Thats awesome
    There is a box picture there. 50 Watts power - 4275 lumens - 4,000 Kelvin - LED Big Bulbs | Rockler Woodworking and Hardware - each bulb is equal to (4) 75 watt light bulbs.
    Drawback - does require some reworking to make work on the enclosure (remove the original shroud, use the lexan shields to make the new tops, make the standoffs and reinstall.
    The pictures do not do it justice on how freakin bright that thing is. You almost need to wear a hat just to cut down on the glare from above.
    Nov 2007
    2151
    I replaced 90% of the lighting in my house, shop even out door lighting with led. Power cost is high around here. The lights I used in shop at first were very harsh to work under, the shadows can be distracting. Then I got use to that light level and now I want more .
    I had 1200 watts of 4ft flor. tube lights replaced with 120 watts of led. Made the shop easy to cool most of the summer, but it warms up slower in winter. I save about 25-45$ a month on power now. I spent about 1000$ so r.o.i. will take a while.
    Nov 2007
    2151
    Quote Originally Posted by mountaindew View Post
Name:	power rates.jpg
    This was on cnbc they were talking about bit coin mining and the power the mining computers use. Anyway I live in an area that is near the $0.21 mark and apparently it would not pay to mine coins around here .
    May 2016
    138
    I just got my mining setup done. But i'm on solar thats already paid for itself
    Following you on IG, same name here but with an i instead of a e, silly swear filter here....
    Jan 2018
    5
    Test of email notification - sorry to those following - trying to debug my account.
    Jan 2016
    386
    Here is another really bright light. It is 100 Watt, 10,000 lumen. I picked one up yesterday at Menards for $29.99 and all I can say is it is really bright.
    https://www.menards.com/main/electri...8886810&ipos=2
    Steve
    Oct 2010
    670
    Just an update for folks. I would recommend only doing the front left and right bulbs. It's damn near blinding with just that. I don't even turn on the other three.
    Later,
    Awall
  1. Enclosure light not working - Puma 230ms
    By Adhawk in forum Daewoo/Doosan
    Last Post: 10-07-2015, 01:28 AM
  2. Replies: 17
    Last Post: 08-03-2012, 11:50 AM
  3. PCNC1100 Enclosure on a $0 budget
    By crawley in forum Tormach Personal CNC Mill
    Last Post: 10-16-2010, 06:55 AM
