587,998 active members*
1,599 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Adding a manual pulse generator to my home CNC
    Mar 2004
    42
    Hello,
    I have acquired a hand held manual pulse generator (I think that's what it's called) which I would really like to integrate into my home CNC mill for jogging the axis. The bad/good thing about the pulse generator is that apparently something electrical is broke on it (which is why they gave it to me). All of the knobs and the main turnwheel thing still operate fine in terms of mechanically. My idea was to use the exiting mechanical switches and wheel and wire them to "something" that could send an input into my machine control. The "something" is what I am looking for ideas on.
    My mill is 3 axis with a xylotex stepper drive and running mach 3 software. My first (and only) idea was to hook up an encoder to the turnwheel and wire it into the computer because i believe the mach3 software can take an encoder input, although I'm not sure if that can then be used to manually jog the mill.
    Any thoughts or suggestions???????
    Thanks for the help.
    Mar 2003
    35538
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Used pulse generator pendants or schematics?
    By AZDEN in forum CNC Machine Related Electronics
    Last Post: 07-17-2007, 02:01 PM
  2. Pulse generator / controller boards for EMC.. which one?
    By ewest in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2007, 11:53 PM
  3. Manual Puls Generator
    By zekk_2 in forum CNC Machine Related Electronics
    Last Post: 02-05-2007, 11:10 PM
  4. USB Pulse Generator support in EMC???
    By acondit in forum LinuxCNC (formerly EMC2)
    Last Post: 01-16-2007, 01:42 AM
  5. Manual Pulse generator?
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 07-24-2006, 04:10 AM
