603,358 active members*
3,121 visitors online*
IndustryArena Forum > CAM Software > Mastercam > advanced multiaxis/5 axis multi surface
Results 1 to 7 of 7
    Sep 2010
    135
    we got this prototype over that is a half a sphere with pockets all around it,
    I said we can make it but I never did nothing like this in my life... we have a 5 axis horizontal machine with b and c axis.
    I was thinking about clamping the stock material on the c axis and program it using a advanced multiaxis/5 axis multi surface.... but can't get it to work...
    I'm just wondering if there is anyone out there that already programmed something like this that would be able to give me some tips...
    thanks all
    Dec 2008
    3211
    A bit more info would be nice....
    anything to hold onto ?
    use a 3 jaw and hold the stock ?
    holes underneath ? make something that can hold (bolt onto etc) the part, then hold that item
    pre-turn the sphere
    use 3+2 instead of 5 axis to do each pocket
    if the pockets are flat bottom, use that face to set the views
    Sep 2010
    135
    Quote Originally Posted by Superman View Post
    pre-turn the sphere
    yes we are doing a plate ring with clamps on the outside...
    can you imagine a half soccer ball with all those faces?
    so this project is something very similar but all the faces have a small round pocket inside...
    can you please explain 3+2?
    I don't have that option on mastercam...
    Dec 2008
    3211
    Quote Originally Posted by PRINT_FX View Post
    It is not a mastercam option,
    but a method of programming, of using planes and strategies, that don't involve the rotary axes moving while cutting.
    you create views of the features that need machining and only do those features that you can get to.
    You are using the axes only for positioning,
    eg. 5-axis swarf is a 5 axis operation, you can also do it by positioning te axes so you can surface the same feature.....it is a longer way to get the same job done
    Sep 2010
    135
    yes Superman.
    you right, I have to spend more time around the project, too bussy over here...
    thanks
    May 2006
    807
    Could you show us the part model, in rendered solid?
    Been doing this too long
    Sep 2010
    135
    Quote Originally Posted by bostosh View Post
    I'm sorry, this is a very underground stage of the project, I'm... myself and lots of people are involved with... can't say no more...
    hope you understande.
  1. 5 axis indexing, not swarf, multi surface etc.
    By rroberto in forum Mastercam
    Last Post: 10-10-2009, 11:04 PM
  2. 5 axis indexing, not swarf, multi surface etc.
    By rroberto in forum Post Processors for MC
    Last Post: 09-08-2009, 01:57 PM
  3. CNC 5 Axis Programmer/Advanced Machinist Knowledge
    By Rotor_nut01 in forum Employment Opportunity
    Last Post: 03-06-2009, 09:18 PM
  4. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  5. CNC multi-axis ques?
    By CNCRim in forum Fanuc
    Last Post: 09-03-2006, 05:13 AM
