587,792 active members*
3,300 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Air turbine spindle attachment, ever used one?
    Aug 2010
    14
    Not sure where this would fit in on the site but I figured maybe here would work.
    I am curious to know how popular they are and if they are widely used? My work is pushing me to try Jig grinding with our Makino F5 and a 30,000 rpm air turbine attachment they purchased a while back.
    I am pretty nervous about this as there are many things related to the machine I need to figure out.
    One example I can think of off the top of my head is that every time you open or close the doors to the machining center the spindle needs to be oriented. Since it does not have thru spindle air it needs to be connected by a hose sticking out the side of the air turbine attachment. I am a bit stumped as to how I am going to get it in and orient the spindle without it rotating 360 to orient the spindle once I close the doors as the spindle is to remain locked when this is in use.
    Anyways, I am starting to plow through this and am a bit lost on it but if anyone who has experience with it could chime in with some words of wisdom that would be awesome!
    Thanks,
    Ryan
    Feb 2009
    6028
    Re: Air turbine spindle attachment, ever used one?
    Ya, thats going to be a tough one. I don't see any simple way around it other than temporarily remove the door key and stick it in the lock, then using a M99 at the end of the program, with a M0 at the beginning. Technically, this would not be against code, since you obviously are not using the ATC, but its pushing it.
    Aug 2010
    14
    Quote Originally Posted by underthetire View Post
    Thanks for the input. That is exactly what I was thinking I would do.
  1. How do I set up GSE2507 4 spindle attachment on a Citizen K-16E
    By petruccifan5000 in forum CNC Swiss Screw Machines
    Last Post: 02-27-2013, 02:49 PM
  2. Replies: 6
    Last Post: 12-23-2008, 02:22 PM
  3. High Speed Spindle Attachment
    By yoopertool in forum Hard / High Speed Machining
    Last Post: 06-20-2007, 12:26 PM
  4. Replies: 0
    Last Post: 10-10-2006, 09:19 AM
  5. Pinnacle XJ-95 & X2 High Speed Spindle Attachment
    By KDN Tool in forum News Announcements
    Last Post: 07-17-2006, 07:28 PM
