603,946 active members*
2,342 visitors online*
    Sep 2011
    "Alarm - Bad Number" and commented code
    So I am trying out SolidCAM.
    The G-Code generated from SolidCAM looks alright to me yet when I load it into my HAAS-VM3 (Fanuc) it gives me an "Alarm - Bad Number" and a number of commented fields which are not commented in the NC file but turns out commented within the controller. The lines that are commented are therefore skipped upon the execution of this particular program.
    Any ideas?
    "O10000 (ITEM STN 10 STRIPPER INSERT)
    N100 (COMPENSATION-WEAR)
    N102 (REV-0.70)
    N104 (MAR-04-2012-3:34:17PM)
    N106 (TOOL 2 - DIA 9.52)
    N1 G90 G17 G40 G80 G00
    N108 M06 T2 ()
    N110 (F-contour)
    (N112 G00 G54 G90 X48.1863 Y-101.6 S1000 M03?)
    N114 G43 H2 Z70.
    N116 Z50.
    N118 Z21.041
    N120 G01 Z12.35 F33.
    (N122 G02 X48.1863 Y-101.6 I-3.8633 J0. F100.?)
    N124 G01 Z10.35 F33.
    (N126 G02 X48.1863 Y-101.6 I-3.8633 J0. F100. ?)
    N128 G01 Z8.35 F33.
    (N130 G02 X48.1863 Y-101.6 I-3.8633 J0. F100.?)
    N132 G01 Z6.35 F33.
    Mar 2012
    Well first off I would put your G54 and G90 on a separate line, as well as your spindle start up. If that's really what the code looks like, it's probably something wrong with your I or J value. If you have cutter comp on this might affect it. I'm not sure if you're using millimeters or not in your values, but you have a .375 EM trying to cut a .304ish hole?
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Replies: 3
    Last Post: 09-04-2011, 10:22 PM
  3. Replies: 0
    Last Post: 09-13-2010, 07:36 PM
  4. Replies: 2
    Last Post: 07-03-2010, 12:27 AM
  5. "tool slot number too large" code
    By dave6 in forum Mach Mill
    Last Post: 10-10-2006, 11:57 PM
