603,826 active members*
3,560 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Check for "Alarm 73 - PROGRAM NUMBER ALREADY IN USE" not active?
Results 1 to 4 of 4
    Aug 2011
    2517
    on my machine (MSG-500 Fanuc 18i) if I read in a program that has the same O-number as one already in the memory that program is overwritten with the new program. Is there a parameter to stop/enable the overwriting and instead generate an alarm? I checked the parameter manual but can't see anything? I remember on Fanuc 0/10/11/12/15/16 that alarm 73 will come up "PROGRAM NUMBER ALREADY IN USE". On the newer 18i series it just overwrites the program! argghh! :/
    Jun 2007
    119
    Param. 3201 bit 2
    Mar 2003
    2932
    #3201 bit 2 - See attached
    Oops... Sorry Viorel26, I didn't see your post. I should have 1st cup of coffee BEFORE sitting down at PC.
    Aug 2011
    2517
    ah yes. thanks!! not sure how I missed that
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Replies: 0
    Last Post: 09-13-2010, 07:36 PM
  3. "jword given for arc in xz plane line number xxx" ???
    By HankMcSpank in forum G-Code Programing
    Last Post: 05-11-2009, 01:28 PM
  4. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
  5. "tool slot number too large" code
    By dave6 in forum Mach Mill
    Last Post: 10-10-2006, 11:57 PM
