I guess you mean the "Plate Thickness" DRO. The name says it all.
Enter here the thickness of the material you are using as a touch plate. Then make minor adjustments to get the result spot on.
This tells the macro what height above intended zero the probe was activated.
For alterations to screens look for "Screen4". It will be found on the Artsoft web site.
Greg
