603,369 active members*
3,281 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Oct 2008
    248
    Re: Another cnc plasma/router build
    Ya I was going to do the same, but the Lottos dealer where I got my plasma from never got back to me regarding the plug
  2. #22
    Feb 2007
    58
    after spending half a day reading through spec sheets and doing searches, I ended up finding a compatible set of plugs for the lotos ltp500d torch. CNX-505, and CNX-510 are the vendor order numbers (not mfg part numbers)
    Electric Scooter Battery Charger Connectors - ElectricScooterParts.com
    these were the best match I could find but were generic with no spec sheet looked right so bought them on a hope. it was like 11 bucks for the pair delivered, they accepted paypal.
    got them today and glad to say they fit !
    edit --
    actually after taking the gun apart, looks like you only need the female plug. I was thinking it required a pass through connection with only one wire switched to complete a connection to the torch end. In the handle though the wires just connected directly to one another through the switch.
  3. #23
    Oct 2008
    248
    I'm glad you found some plugs, they will a cleaner setup
  4. #24
    Sep 2014
    14
    Hey guys, I've been doing a bit of research and am a bit bored so want to try out building a plasma table so I can start tinkering at home. I'm interested in your build mike.
    Where did you get your plans from?
    In Aus the rack and pinions are very expensive so I was looking for alternatives in timing belts and chain drives.
    You say your chain drive works well I'd be interested in how it's working.
    Cheers KD
    Sent from my iPad using Tapatalk
  5. #25
    Oct 2008
    248
    Quote Originally Posted by crazyk View Post
    Cheers KD
    Hello Crazyk, sorry I didn't build the machine using plans. I kinda had a design in my mind and went that route. Yes the roller chain seemed to work well, it's a good starting place.
    Mike
  6. #26
    Sep 2014
    14
    Cheers mike
Page 2 of 2 12
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. 4 x 4 Plasma/Router Build
    By sodfarmer in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-23-2009, 10:51 PM
  3. Plasma/Laser cut parts to build a CNC Router
    By NEATman in forum DIY CNC Router Table Machines
    Last Post: 01-26-2007, 11:29 PM
  4. 1st build: Router/Plasma
    By krebsatm02 in forum DIY CNC Router Table Machines
    Last Post: 06-25-2005, 03:56 PM
