603,323 active members*
4,197 visitors online*
    Aug 2016
    Any advice how to fix this?
    A while ago I build this machine and everything works fine, just some easily fixable problems. This mounts seen on pictures needs to be fixed I just don't have idea how to fix it easily and effective. Most of machine is made strong enough, just this mounts lose allot of accuracy.
    Do you have any idea how to fix that?
    Maybe consider replace lead screws with timing belt (because machine have mill and laser)?
    Thank you
    Attached Thumbnails Attached Thumbnails IMG-0448.jpg   IMG-0447.jpg   IMG-0425.jpg   IMG-0426.jpg
    Apr 2004
    5948
    Re: Any advice how to fix this?
    Are you saying that the connection between the gantry and the leadscrews is loose? If so, see if you can tighten it, and use some Loctite to keep it from working loose again. If that doesn't help, try using different pieces of metal to connect the two parts more rigidly, and perhaps more screws. I think that would be better than replacing the whole mechanism with open belts, which aren't usually recommended for routers.
    Andrew Werby
    Website
    Aug 2016
    Yes connection between the gantry and the leadscrews. I was thinking to make new connection because with this connection nut can rotate a little bit and creating backlash.
    How much power would machine lose if I replace leadscrews with timing belts?
  1. Need Help/Advice
    By jeremywilliams in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-07-2016, 09:58 PM
  2. Material advice and advice needed
    By kiyoukan in forum Mechanical Calculations/Engineering Design
    Last Post: 02-15-2012, 08:20 PM
  3. General advice and equipment advice
    By GeorgiaRaised85 in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2010, 11:00 AM
  4. New and in need of some advice... well alot of advice!
    By GoonShoes in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2007, 01:03 PM
  5. Looking for Advice...
    By pspiech in forum Employment Opportunity
    Last Post: 12-14-2006, 03:08 PM
