Originally Posted by
FuriousGeorge
I've seen those coolant systems before on this forum and they look great. Have you ever used it in conjunction with Tormach's ATC? My big concern is that with all that coolant spraying around, I would be soaking my tool shanks. I'd hate to invest the time and money in a coolant system that will end up making my cutters pull out. That's happened to me before with the stock coolant pump if the pressure is maxed and the positioning is bad.
Quacker, why did you settle on 0.5 PSI? How long does a tank of coolant last you?
