588,340 active members*
5,463 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Anyone have a comparison table for different models of BF20 size mills?
    Aug 2012
    279
    I have seen a nice comparison table for mini mills at Mini Mill Comparison - LittleMachineShop.com but haven't found anything similar for slightly larger mills. Anyone know of one for BF20/G0704/etc.
    May 2008
    1185
    Re: Anyone have a comparison table for different models of BF20 size mills?
    The BF-20 and G0704 are vary close to the same size but with different layouts. The tables have the same working area but the PM-25 has different end plates.
    Each major competent like the column, base and table weigh about the same. The heads are the same with different motors.
    Both are good mills.
    youtube videos of the G0704 under the name arizonavideo99
  1. Adjusting BF20 to be square to table
    By outsider787 in forum Benchtop Machines
    Last Post: 07-31-2011, 03:14 PM
  2. BF20 Machining underside of X table
    By bladehunter in forum Benchtop Machines
    Last Post: 11-30-2009, 11:26 AM
  3. Table Size for a TM3?
    By schoobie in forum Torchmate
    Last Post: 03-22-2008, 06:40 PM
  4. table size
    By Jimmyh in forum Mach Software (ArtSoft software)
    Last Post: 08-30-2007, 04:33 PM
  5. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
