Originally Posted by
marq_torque
__________________________________________________ ________
Also my encoder supplier suggested to run -A and -B through whole length of cable and ground them to power supply of encoders.
Why would you ground the A/ & B/ of the encoders? These transition between 0 and 5v with respect to common just as the A & B do.
This would essentially short the complements to ground.
marq_torque
__________________________________________________ __________
Was thinking that computer's earth terminal and Vfd's Earth are going to same supply common that's why giving the noise!!!
I would suspect that the common grounding is insufficient if anything, you need to take the PC P.S. common and all shields and encoder power supply common to a central point including the service ground.
Have you also bonded the VFD and motor frame to the star point ground?
Al.
Albert E.
