587,518 active members*
3,632 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Porter cable spindle noise reduction or alternative?
Results 1 to 7 of 7
    Feb 2005
    28
    I am using a porter cable 7310 laminate saw on a homemade gantry table, it works well but is very noisy even free-spinning. Is there any way to quiet these down? they seem to be quite popular so hopefully someone has info. The noise seems to be from both its bearings and brushes, and present on all of them, new or used
    Thanks in advance
    Mar 2003
    35538
    You can use a router speed control to slow it down a little, which will make it a little quieter, but you may lose a little power. Some people build enclosures around their machines to keep in the noise. You may find that if you quiet it down, that the bit can actually make more noise than the trimmer when cutting, though.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2003
    1079
    Just to build on what Gerry said, I have a Makita RF1101 and it is very quiet - until you start cutting. If noise is an issue with the neighbours, then an enclosure can be extremely effective.
    Aug 2004
    2849
    I have a Hitachi 3 1/4 HP....it's barely audible when running and when cutting it is still very quiet. My Craftsman router of about 1 1/2 HP is very loud when running and extremely noisy when cutting.
    Mar 2003
    35538
    Quote Originally Posted by ViperTX
    A lot of that depends on what your cutting, the tooling used, and how sharp it is.
    Gerry
    Feb 2005
    28
    Hmm, I have tried cutting AL with 2 flute and 4flute cutters (0.05-0.125) and it makes almost no difference in noise level. I have a speed control but it stays very noisy down to about 2k? RPM which would cut the feed rate too much. The main reason I went with this spindle was easy mounting
    I will probably have to build and enclosure sooner or later but it is a 48' x 36' machine.
    What is the source of the higher pitched whine in the router? I was thinking of removing it is cooling fan and cooling it with the cutting lubricant in a copper tube. That might cut the whoosh noise or destroy the router in the process
    Thanks!
    This is my first real cnc project
    Apr 2003
    1079
    I think it is always gonna be noisy cutting aluminium
    You could always enclose just the moving part of the machine, using something like soft plastic fingers to allow it to move over the material. Might work?
  1. Porter Cable 690LR Router
    By CNCRob in forum DIY CNC Router Table Machines
    Last Post: 07-09-2018, 01:11 AM
  2. spindle electrical noise
    By balsaman in forum CNC Machine Related Electronics
    Last Post: 06-02-2013, 12:01 AM
  3. porter cable collets
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 07-09-2008, 10:40 PM
  4. Z axis for porter Cable router
    By camfambmw5 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2003, 03:55 PM
  5. Mounting a porter cable router
    By camfambmw5 in forum DIY CNC Router Table Machines
    Last Post: 09-28-2003, 02:38 PM
