587,672 active members*
5,046 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Assembly without messing up table top
Results 1 to 6 of 6
    Apr 2008
    384
    I'm wondering what methods you would use to assemble something such as a square frame on your nice flat assembly table without messing up the table's surface with glue ?
    Mar 2003
    35538
    Cover it with plastic sheet, or newspaper.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2008
    384
    Didn't think of that, thanks.
    Mar 2003
    35538
    If you have a wood table, a good coat of wax on it will make it easy to clean up any glue spills.
    Gerry
    Mar 2004
    636
    Melamine tables are nice
    I have a sheet of white melamine on my workbench. When I am done, I let the glue dry and am able to come back the next day with a chisel or putty knife and scrape it right off without damaging the top. If you don't want to wait, a damp cloth when the glue is still wet wipes off very easy from the melamine as well.
    I have also seen workbenches with a replacable 1/4" hardboard sheet on them. When it get to marred up, simply replace it. I wasn't real fond of this method, but it may work for others.
    Dan
    Check out what I am working on at www.routerbitz.com!
    Apr 2008
    384
    Thanks for the advice, I'd forgotten about Melamine - I use a Melamine table for my soldering and it is resistant to just about everything.
  1. assembly in nx-6
    By sk96_me45 in forum UG NX
    Last Post: 05-10-2010, 03:26 PM
  2. Assembly Table / Vacuum Frame Press
    By ger21 in forum WoodWorking Topics
    Last Post: 03-16-2009, 04:07 PM
  3. Need help with assembly please
    By dpark1 in forum Solidworks
    Last Post: 07-26-2008, 03:43 PM
  4. A light-weight table/bearing assembly with a low part count.
    By greybeard in forum Linear and Rotary Motion
    Last Post: 11-10-2005, 12:16 AM
