603,946 active members*
2,636 visitors online*
    ATC Compressor Selection
    Hi All,
    New to the forum and new to CNC ownership. I recently purchased a machine from Style CNC, model STM 1530C, and am in the process of setting it up. I need to purchase a compressor to run 3 components of the machine: the ATC spindle which is a HSD ES 951 12 position linear, the pop-up alignment pins, and a set of pneumatic hold down rollers. I asked the manufacturer about the pressure and airflow requirements for the machine and was somewhat shocked at the response. They told me I needed 1 cubic meter per minute at 6-8 Bar, which translates to about 35 CFM at 100 PSI. That amount of airflow seemed excessive to me from comparing the requirements of similar machines made by Camaster. Is anyone running a machine with similar components? If so, what size compressor have you found to be adequate?
    Jan 2024
    5
    Re: ATC Compressor Selection
    @Drive Mad 2: Double-check the air requirements: The manufacturer's stated requirement of 1 cubic meter per minute at 6-8 Bar (35 CFM at 100 PSI) does seem quite high, so it's a good idea to verify this with them. Ask them to explain in more detail why such a large air supply is needed for your specific machine model and components.
    Research similar machines: As you mentioned, compare the air requirements to other similar CNC machines, like the ones from Camaster. This can help you determine if the manufacturer's specs are accurate or potentially excessive.
  1. Replies: 16
    Last Post: 08-24-2022, 09:56 PM
  2. Replies: 7
    Last Post: 05-21-2021, 11:23 AM
  3. Compressor choice for ATC
    By sansbury in forum Tormach Personal CNC Mill
    Last Post: 10-02-2018, 05:34 AM
  4. Need to bypass Random selection/shortest path tool selection method
    By Tizbass in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2012, 02:38 AM
  5. PDB/ATC compressor
    By Dark Side in forum Tormach Personal CNC Mill
    Last Post: 12-24-2011, 09:53 AM
