http://www.automationtechnologiesinc...012/02/C10.pdf
Why do you need resistors on the NPN proximity sensors? I cannot get my sensors to work with the resistors in place!
Something else I noticed is the direction seem wrong with regards to the 10-15 inputs. the only way I can get the board to work on a 'ground' trigger signal is to switch the value to 'pull-down' when it clearly shows 'pull-up' when doing touch off sensing.
