603,321 active members*
3,431 visitors online*
    Nov 2005
    43
    axis overcurrent
    I searched this forum for some info but I did not find anything useful. So I apologize if this question is redundant.
    I have a VF2 that gave me a Z axis overcurrent alarm. I shut down and cleaned out the brushes and tried again. Same thing! I swapped the Y axis and the Z axis boards and the problem moved to the Y axis. Now my question is before I go and call HFO for a replacement board has anyone gone any deeper in finding the problem on the board? I already checked the fuses on the board and now I am moving to the resistors. Any guidence would be appreciated.
    John
    Apr 2007
    178
    you can replace the fets which are usually blown relatively cheap you can ohm them out and see the blown ones they are the 4 discs on the rear part of the board on the heat sink.
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  2. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  3. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  4. VF-2 overcurrent on Y axis
    By coalstove in forum Haas Mills
    Last Post: 08-03-2006, 08:32 PM
  5. alarm! spindle overcurrent
    By jianjianca in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2006, 04:35 AM
