We have a 1992 Fadal 6030 with the Numatix CNC retrofit. The problem I am having is that the B-axis will only rotate 21 deg. one way and 28 deg. the other way. Is there a way to change this setting on the axis card for more swing? I am thinking that this a Fadal upgrade that will cost mucho dollars. I was hoping the Numatix retrofit would change it but it still uses the Fadal control cards.
Thanks in advance.
