587,744 active members*
3,529 visitors online*
    Jul 2008
    22
    B axis rotation formula.
    My mind has gone blank!!
    Say I want to drill a hole at 45 deg.
    Assume that the component is set up at machine-x0 y0 and the hole being drilled is lined up along y0.
    B0 is the front of the part and the hole being drilled is at B45.
    When using a horizontal machining centre, the tombstone pivots around the centre of the tombstone.
    If you then have a fixture on the tombstone and then the component then the co-ordinate of the hole could be at say Z300.
    This means that when you rotate around to B45 the component is not rotating around the centre.
    Using trig calculations how do you arrive at the new x and z co-ordinates.
    There is an excel based calc on the internet but you have to pay for it called 'fixture offset calculator'
    If anyone has a freebie thaen that would be great.
    Hope I have explained this.
    May 2005
    7
    Here is how I do my offsets.
    Attached Files Attached Files
    Jul 2008
    22
    hi for some reason i can not open this file. is it corrupt????
  1. Formula for B axis rotation on machining centre?
    By fitzpatrick2362 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-25-2009, 04:36 AM
  2. Fanuc OM B axis rotation
    By Kev4966 in forum Fanuc
    Last Post: 10-16-2008, 08:09 AM
  3. Rotation control help on A axis
    By Art Ransom in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 01:04 PM
  4. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-18-2006, 02:36 AM
  5. Converting X axis to A rotation
    By quemast in forum GibbsCAM
    Last Post: 06-09-2006, 04:17 PM
