603,341 active members*
5,727 visitors online*
Results 1 to 4 of 4
    Feb 2011
    B-axis rotation - shortest route
    We have a Mazak 630 horizontal machining center and the B-axis always rotates CW, when I would like it to rotate CCW sometimes (to take the shortest route). The programmer before me said he thought it was a parameter change, but wasn't sure and can't find the parameter book. (It sure sounds like it would be a parameter change).
    Anyway, I was wondering if there could be a macro written for this. I'm a rookie when it comes to writing macros so was looking for some help. It a Mazak M32+ control.
    Thanks for any help.
    Jun 2008
    1511
    Hey Phil,
    I posted this over in the machinetoolhelp forum for a different user name of "cncguy" but considering it is the exact same question I am going to post it here as well incase it helps anyone else.
    Is it safe to ass u me that you are cncguy as well?? A lot of the same questions from 2 different users in 2 different forums.
    I am not up on the Mazak programming lingo so I will not be able to help you with code. However a macro will not give you what you want. If you wanted to do shortest distance without the parameter change then you would have to program a B- or B+ from the position you are at or from B0.
    Now the machines that I am familiar with will have a parameter setting for this which has already been pointed out to you. I would recommend finding the parameter manual online or by other means and simply setting the parameter and no additional programing is required. I have done this for all the rotary axis machines that I have setup.
    In Fanuc controls it is determined by bit RINC which will move the rotary axis in the direction that is the least movement. I have also found setting bit RDAx for the rollover function. This way the control will not go past 360deg. Once it reaches 360 it will roll back over to 0 instead of adding to the 360deg.
    Stevo
    Feb 2011
    Yes, that would be me as well - trying to reach as many people as possible...and when and if I get the answers, I will always post them in all forums to help others. I think these forums are awesome and have been a great help to me as I'm trying to take my skills to a higher level.
    Thanks for the info, as always...
    - Paul
    Jun 2008
    1511
    Sorry I could not be of more help. I just know the Fanuc bits for this. I am sure someone will have what you need.
    Stevo
  1. A axis rotation ????
    By dunnitagain in forum Fadal
    Last Post: 07-29-2011, 01:50 AM
  2. Route an Arc in the Z Axis
    By ErikGun in forum CNC Machining Centers
    Last Post: 12-27-2010, 08:27 AM
  3. B axis rotation
    By fitzpatrick2362 in forum MetalWork Discussion
    Last Post: 10-12-2009, 12:06 PM
  4. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-18-2006, 02:36 AM
  5. Shortest path between points? Software?
    By jderou in forum Uncategorised CAM Discussion
    Last Post: 12-22-2005, 11:45 PM
