587,189 active members*
2,316 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > back up of the machine, having Heidenhein control iTNC 530
    May 2008
    4
    Hello!
    I have mostly worked on Heidenhein control iTNC 530. The new model of machines has separate Hard Disk, which has easy external access. I usually Colon (backup) this hard disk with Norton Ghost, to use it again when required.
    I want to make back up of the machine, having Heidenhein control iTNC 530 and following sticker on the control card.
    MC 422 CE
    Id. Nr. 357 630-01
    S. Nr. 11 677 252 B6
    How can I make backup of this Machine. Kindly help in this connection.
    Hoing to hear from you soon. Thanks.
    Abdul Haq
    May 2008
    26
    The Tnc530 has an automatic backup using either the TNC Remote or at the control itself. (TNC Backup) Go to Heids website and you should find the info.
    Jul 2008
    26
    if your control has usb, you can use that. if not the TNCcremoNT software free at the site.
    MoRdAnTlY [Mr. Wolf '91 - '10]
  1. Heidenhein TNC2500
    By nrpt in forum Controller & Computer Solutions
    Last Post: 03-26-2009, 08:40 PM
  2. Wanna make one cut without machine going back and forth
    By Delanoman in forum G-Code Programing
    Last Post: 02-27-2009, 05:22 PM
  3. Replies: 2
    Last Post: 11-07-2008, 11:19 PM
  4. Brake press CNC back gauge control
    By impax in forum CNC Machine Related Electronics
    Last Post: 01-17-2008, 01:17 PM
  5. BP Interact 412 Heidenhein 351
    By besc in forum Bridgeport / Hardinge Mills
    Last Post: 10-14-2006, 05:08 PM
