603,900 active members*
3,085 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Ballscrew mounting blocks that doesn't cost and arm and a leg?
Results 1 to 5 of 5
    Jun 2010
    I'm picking up a nice pair of ballscrews (C5) and need to get some mounting blocks. The blocks end up costing more than the screws. $300 for the fixed end and $90 for the free end. Is there any place that have better prices? Thanks.
    Mar 2003
    35494
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2003
    24260
    Did you check Misumi? Thats where I get mine.
    Al.
    Albert E.
    Jun 2010
    Thanks for the quick reply guys. I'll check out both places.
    Mar 2006
    2712
    Be sure to include the price of the bearings in your total. Some come with bearings and some without.
    Ballscrew fixed end bearings are most often paired, precise, 45-60 deg. angular contact bearings with a rather heavy pre-load. $$$$$$$$$$$$$$$ Floating end not so much.
    Dick Z
    DZASTR
  1. Adjusting ballscrew bearing blocks
    By sansbury in forum Benchtop Machines
    Last Post: 11-30-2008, 04:45 PM
  2. RFQ: ballscrew bearing blocks/flanges
    By margni74 in forum Employment Opportunity
    Last Post: 08-17-2007, 10:08 PM
  3. Cheap source for Ballscrew Support Blocks?
    By geocentric in forum Linear and Rotary Motion
    Last Post: 06-29-2006, 01:00 PM
  4. Ballscrew mounting
    By m_c in forum Linear and Rotary Motion
    Last Post: 03-11-2006, 10:51 PM
  5. Linear shaft mounting blocks
    By WarrenW in forum DIY CNC Router Table Machines
    Last Post: 10-27-2005, 04:01 PM
