587,172 active members*
3,026 visitors online*
Results 1 to 6 of 6
    Jan 2022
    107
    Beta and other stuff
    As mentioned in another thread, there should be a better communication somehow what is beta and what not.
    For example i never realiced that the machine 3d Display is some kind ov preview and not official supported.
    The same is also for the very latest version. You called it a beta in another thread, but it is not clearly visible.
    Just for Understanding: I am using the software in productive environment on large scale CNC Machine and having unexpected behaviour confuses not only me, but my co-workers who are not familar with programming or any special knowledge.
    On the other hand, compared your software to others. There are many abilitys and I realy like the way it is working. Even if its not industrial style. And i knew from own projects how frustrating it could be if updates are not working as expected or customers are not satisfied. .
    Maybe you could think of something like an extended support for an annual fee or something like that to separate industrial customers from hobby.Because your software and devellopment is realy worth more than just a single payment.
    Mar 2017
    1328
    Re: Beta and other stuff
    Thank you. Perhaps this is really something we should consider.
    I apologize for inconvinience. There were some major issues fixed and because other changes were only cosmetic I decided to to this.
    Send me your 3dobj.txt file and I'll fix it for you.
    Jan 2022
    107
    Thank you. Attached you will find my 3dobj.txt
    Maybe you could answer a short question: How could I add custom images in dialogs?
    So far I have
    (dlg,data::myimage.png, typ=image, x=0) ,
    but that doesn't show my image. Maybe I have placed it in the wrong place.
    Mar 2017
    1328
    data:: means image is internal and will not work with your images.
    Check "GuessNumber.nc" example from samples.
    Aug 2011
    252
    Quote Originally Posted by awpross View Post
    I'm not on that side, I make parts with my DIY CNC but not at an industrial scale, is still a hobby.
    However, I suggest that the beta version be released separately with the option to download and test, but if something doesn't work, it should be there the option to download the previous version again and use it until the possible problems are solved. Any new version should be beta to begin with, because no matter how much it is tested by the PlanetCNC staff, they can still miss something and have small malfunctions. It's just my opinion, maybe good, maybe not.
    Mar 2017
    1328
    I think this is it.
  1. Considering the Beta...
    By CabinDigital in forum Tormach PathPilot™
    Last Post: 03-22-2015, 05:06 PM
  2. Replies: 0
    Last Post: 09-17-2014, 05:51 AM
  3. Mach3 tuning (cuts small stuff fine, but is off on big stuff)
    By jdbaker in forum Mach Software (ArtSoft software)
    Last Post: 03-15-2007, 05:30 PM
  4. welding thick stuff to thin stuff - need advice
    By cross6 in forum Welding Brazing Soldering Sealing
    Last Post: 01-13-2005, 08:39 AM
  5. Beta 7 Available
    By robgrz in forum News Announcements
    Last Post: 09-28-2003, 01:13 PM
