588,337 active members*
4,745 visitors online*
Results 1 to 12 of 12
    Oct 2006
    84
    BIG diameter ballscrews, any use?
    I got a bunch of ballscrews pretty cheap from an auction. They range from 15mm diameter to well over 2.5" in diameter.
    The two I had in mind are brand new German STAR screws.
    One screw is 84" long and has something like a 50mm diameter.
    One screw is around 72" long roughly 50mm diameter. Would make a hell of an X axis (nuts)
    TOTALLY overkill for a home cnc machine.
    Can a run of the mill Keling servo motor (maybe the 1100oz) even turn these puppies?
    I'd like to try and use 1, maybe toss the other on ebay
    Mar 2010
    can you post some pictures ? And geared down why not ?
    Mar 2012
    it's a good bargain to buy from auction. and leave one for you ,the others toss to ebay or other B2B site.
    Oct 2006
    84
    Quote Originally Posted by Hommersimpson View Post
    no pics yet, they are sitting at the shop.
    Jul 2009
    419
    On another forum, a guy that seemed to know his stuff said that acceleration becomest difficult at the screw, not the weight of the gantry.
    That means that the 50 mm ball screw would be totally useless for a home cnc.
    I built my cnc to advice from another person that should know his stuff, the most important bit being to use high pitch ballscrews with high torgue motors. This seems in line with the other guy's advise.
    High pitch means the motors operate at low revs, where torgue is highest.
    I now have blistering acceleration.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Oct 2006
    84
    Quote Originally Posted by CaptainVee View Post
    Link to the other forum?
    I'm at work right now do I don't have the link, However, last night I found a page where a guy was using a pretty beefy screw and was having success by just gearing it down a bit.
    I'm currently getting an easy 120+ipm without trouble on my gantry with close to a 4' long close to 1" diameter gantry screw and a tiny 30 oz-in litton clifton servo motor.
    Apr 2004
    5760
    At least you won't have much trouble with "whipping"...
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Oct 2006
    84
    Quote Originally Posted by awerby View Post
    Andrew Werby
    no kidding, ha.
    I've wanted to try and get an AC servo motor up and running with a granite devices driver as an experiment. maybe this might be a good project to try. if i'm not mistaken, ac servos have a pretty flat torque curve through a large rpm band
    Jan 2006
    481
    Hi , ebay link isn't working my end when clicked on, Have you sold the ballscrews ? if not , What prices do you have on the 50mm ball screws ?
    Cheers
    For Sale - ( Melb, Australia ) Heenan & Froude G490EH Engine Dynamometer. High Speed /Horsepower rating
    Oct 2006
    84
    Quote Originally Posted by FPV_GTp View Post
    Cheers
    Hi, that wasn't a link to an actual auction, but rather a link put in by the ad software on the cnczone site.
    haven't even thought of a price yet... I'm in the USA though, shipping would be expensive to Australia. Feel free to PM me about it. Im going to grab some pics tonight. got a couple of shorter ones too.
    Apr 2007
    1955
    If you have it, the other interesting info about bal screws will be:
    - Rotating nut or rotating screw
    - Picture of the screw ends, so people know what mounts will be needed
    - Screw lead pitch - how much the nut moves for each rotation
    - Screw grade. A rolled C7 grade is entirely different than a ground C2 grade.
    I would think that finer pitch screws would be better for metal machining, and coarser ones for routers, but there is some flexibility in that.
    Oct 2006
    84
    Quote Originally Posted by harryn View Post
    Yo Harry,
    The 3 screws (2 long 50mm diameter 1 short 40mm diameter) are all rotating screw, 10mm pitch. The STAR specs I've seen claim its a rolled C5 grade, I thought rolled maxed out at C7. I've got C3's on my current machine cause they were cheap.
    The ends were factory machined to accept 30mm and 35mm bearings. I've got some cheapo angular contact bearings on order just so that I can get the ball rolling and build some bearing blocks.
    At some point I'll get back to the shop and take pics.
  1. what diameter bit for cnc?
    By forgetcolor in forum CNC Tooling
    Last Post: 03-03-2009, 10:09 PM
  2. rod diameter
    By jwest in forum DIY CNC Router Table Machines
    Last Post: 12-31-2008, 07:11 PM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  5. diameter off
    By mike9696 in forum Fanuc
    Last Post: 04-11-2007, 01:32 AM
