603,344 active members*
3,667 visitors online*
IndustryArena Forum > Community Club House > Birchwood Casey aluminum black oxide, anyone use it?
Results 1 to 8 of 8
    Oct 2007
    307
    Looking for a economical way to black coat some of my products that are aluminum and I do not have a local anodizer anymore. Has anyone used this from Birchwood Casey? Im gonna send them a few test pieces and check durability.
    http://www.birchwoodcasey.com/metal/aluminum.html
    Feb 2005
    753
    If it is low temp black oxide it isn't as good as the high temp black oxide. Also, black oxide is more of decorative.
    If you are looking for low cost message me up and I will quote you on some parts. If you are in texas I could have them in an out in a week back to your shop.
    Oct 2007
    307
    Its 200* temp. Point of doing it in house is so I dont have to pay shipping costs to and from a outside shop. Some of my parts are fairly large.
    Jan 2005
    15362
    aaron p
    This is nothing like anodizing, it is still soft like the base metal you are putting it on, if you were going to do use this process, then you could do the anodizing your self just as well
    Mactec54
    Apr 2004
    5948
    Yes, I've used it
    I think it was called "AlumaBlack". But like the guys said, it's nothing like hard anodizing; it just puts a black coating on the aluminum that's easy to buff off the high spots and show the detail by contrasting with the darkend low areas. Even light handling will rub it off.
    Andrew Werby
    www.computersculpture.com
    Sep 2009
    84
    There isnt any coater near you? Aprox where are you located?
    Oct 2007
    307
    Im in corpus christi, tx. Sadly, a city of 500,000+ with refinerys and oil has no professional "public" anodizing shop. I might get with MBG on some nuts I need anodized.
    Feb 2005
    753
    Quote Originally Posted by aaron p View Post
    Thanks for thinking of me and my company.
  1. How to tell the difference in Black ABS VS Black Delrin?
    By conceptmachinin in forum Material Machining Solutions
    Last Post: 10-17-2011, 03:43 PM
  2. Black areas on anodized aluminum tags
    By firejoe911 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2009, 06:10 PM
  3. black oxide
    By MBG in forum Employment Opportunity
    Last Post: 12-16-2009, 06:23 PM
  4. black oxide for aluminum diy
    By georgebarr in forum MetalWork Discussion
    Last Post: 12-01-2009, 12:33 PM
  5. Why are my aluminum parts turning black?
    By widgitmaster in forum MetalWork Discussion
    Last Post: 09-27-2006, 04:10 PM
