587,884 active members*
3,733 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > BMC20 (ish) ballscrew bearings
    Mar 2009
    82
    Hi Guys!
    I've recently acquired a VMC that is branded up as something other than a Hurco, but has a Hurco BMC 20 Iron underneath. I've concluded that the Y axis ballscrew bearings need replacing, which looks quite a straight forward job. I also have an assembly diagram, which tells me the part numbers etc.
    I just thought I'd check with someone who has some experience with this task before I get myself in lumber. My machine has a fanuc control with AC servos. Should the orientation of the pulleys / motor / ballscrew be maintained during dissassembly / assembly? I'm wondering if the machine will reference correctly if the orientation changes. I'm unsure of the reference sequence that a fanuc control uses to achieve machine zero.
    Any other helpful pointers would be greatly appreciated.
    Thanks.
    Feb 2009
    53
    Re: BMC20 (ish) ballscrew bearings
    Here is the thread where Bloke gives all the information I needed to replace mine. Yes, it is all pretty straight forward and you shouldn't have any trouble doing it.
    http://www.cnczone.com/forums/hurco/...ml#post1459194
  1. Replies: 8
    Last Post: 06-30-2014, 06:22 AM
  2. Replacing Ball Bearings in a Ballscrew Nut...
    By abomb55076 in forum BallScrew Repair
    Last Post: 04-02-2014, 03:29 PM
  3. Design question regarding ballscrew and bearings
    By taskman in forum Mechanical Calculations/Engineering Design
    Last Post: 12-13-2013, 05:20 AM
  4. Position of thrust bearings on ballscrew
    By M100 in forum Linear and Rotary Motion
    Last Post: 08-10-2007, 05:25 PM
  5. Where to get metric bearings for ballscrew?
    By gentoo in forum DIY CNC Router Table Machines
    Last Post: 12-22-2004, 09:00 PM
