603,384 active members*
3,158 visitors online*
Page 1 of 9 123
Results 1 to 20 of 174
    May 2006
    238
    building 2 5x10 plasma tables
    started 2 5x10 tables. got most of the machining done on all the alum parts.
    Have a few photos of the progress. Using candc electronics. More details later
    Dave
    Attached Thumbnails Attached Thumbnails IMAG0152.jpg   IMAG0158.jpg   IMAG0159.jpg   IMAG0160.jpg
    Jan 2011
    I like the buggies in the background.
    Carl
    Oct 2008
    95
    Looking good..............jb
    Jan 2009
    87
    Nice build! Are you using steel for the gantry too?
    Anything is possible, just build it!
    May 2006
    238
    Yes the gantry will be steel. We will be using the tables for plasma and router table. Here is the link to the first table i built, http://www.cnczone.com/forums/plasma...d_4x10.html.It will be very similar to this table
    Dave
    Mar 2010
    47
    I just LOVE LOVE LOOOOOOOVE your builds dnelso, the engineering, the planning and the great looks.. just truly inspiring!!
    May 2006
    238
    Thanks Andikidd, Did you finish your table?
    Dave
    May 2006
    238
    more progress
    got a few more things done
    Attached Thumbnails Attached Thumbnails IMAG0175.jpg   IMAG0178.jpg   IMAG0186.jpg   IMAG0183.jpg
    Oct 2008
    95
    Dave that is a very clean and neat build. The nicest I've seen so far.....jb
    Feb 2009
    227
    Nice!!!!
    Dnelso,
    Your build looks very nice... I followed your entire first build with interest. Ive noticed you made a few minor changes but overall kept the same exact design as #1. I like your lcd monitor stand, I bet alot of people miss that in the photos. Good Luck... :cheers:
    May 2006
    238
    thanks dustin and Boogiemanz. I only changed a few things on theses tables. The table is 5x10 the old table was 4x10. The gantry is also 3 inches higher.I want to use a 4th axis for notching tubing on these tables. I still have to machine a few more pieces and am waiting on the water trays. Here are a few pics of the progress.
    Attached Thumbnails Attached Thumbnails IMAG0207.jpg   IMAG0206.jpg   IMAG0219.jpg   IMAG0227.jpg
    May 2006
    238
    bearing blocks that hold the shaft for the pinion drive
    Attached Thumbnails Attached Thumbnails IMAG0232.jpg   IMAG0234.jpg   IMAG0235.jpg   IMAG0237.jpg
    Oct 2008
    95
    Dave, I have been getting to do a little on my machine. I don't have the benefit of a floor plate like yours and squaring and and leveling is a lot tougher. I used 4x8 tubing because I had it, and put an 1/8 bottom in it for a water bed. I used an 80/20 brand slotted extrusion in a 1"x3" configuration to keep my linear rails and 1/2" gear rack parallel, and am in the process of getting them fastened to the sides of the table.
    I noticed you have added more adjustment on these tables. I'll probably be doing that in a couple of weeks. I appreciate your sharing.. you are sure helping me..............john
    May 2006
    238
    Here are a few more pics.Got the gear boxes finished.Put the bearing races in with the hot plate.Had to drill lots of holes in the gear rack. Should have some movement this week i hope
    Dave
    Attached Thumbnails Attached Thumbnails IMAG0262.jpg   IMAG0263.jpg   IMAG0264.jpg   IMAG0255.jpg
    Feb 2011
    Hi guys first time poster long time lurker, just doing my homework - hopefully starting a build soon.
    Dave, can you please tell me more about your linear guides and rails, sizes on X and Y, Hiwin HG I presume, load type, preload code. I also noticed you used flange type guides on this build? Do you think there would be any advantage of using twin rails on the x axis for routing. Great build Dave, looks very professional.
    May 2006
    238
    Here are the rails that we used. The first table i built used 25mm rails. These rails are 30mm and were cheaper.I like the flange mounts. I have used the router to cut wood and some alum. For what i cut i don't see a need for 2 rails on the x axis.
  17. #17
    Feb 2011
    Any more progres Dave ?
    What do you think of these rails with racks attached.
  18. #18
    May 2006
    238
    Blarb
    No major progress. Got all the racks mounted on both tables. I like the rails with the rack on them i just wonder what the cost is. They are hardened so the gear would wear and the rack wouldn't that's good.
    Dave
  19. #19
    Feb 2011
    I dont think ill be getting those $660.00 per metre $99.00 per block. I would like to come up with a way to make the racks adjustable or do you think it would not be necessary ? Does your pinion keep the same backlash the full length of the table.
  20. #20
    May 2006
    238
    I had a feeling they would be expensive. When i mount the rack i used a machined spacer off the rails so the spacing is the same the length of the rail.If the spacing is correct you will not have any backlash issues. I tried a spring mounted gear reduction box on a different project and had to run a lot of spring tension to get the backlash out. The pinion gears showed a lot of wear in a short period of time. With this system i don't have those problems.
    Dave
Page 1 of 9 123
  1. Building another 5x10
    By dnelso in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-10-2015, 12:40 AM
  2. Building a 5x10 table with HBD gantry
    By mecatrodatos in forum Waterjet General Topics
    Last Post: 11-07-2012, 02:38 AM
  3. PRL motorsports 5x10 plasma table
    By Prl motorsports in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-13-2012, 09:09 PM
  4. Anyone in the UK building DIY plasma tables?
    By adscnc in forum Waterjet General Topics
    Last Post: 01-02-2012, 03:23 PM
  5. Precision Plasma LLC 2x2 Portable Plasma Tables for $1950
    By rchacich in forum News Announcements
    Last Post: 11-06-2010, 04:47 AM
