603,319 active members*
2,878 visitors online*
Page 2 of 9 1234
Results 21 to 40 of 174
  1. #21
    Feb 2011
    How are the tables going Dave ?
  2. #22
    May 2006
    238
    movement
    Finally after a few weeks of getting nothing done we have movement. motors are running at 1000ipm. Everything looks good so far.Hoping to get these tables finished up in the next couple weeks.
    [ame=http://www.youtube.com/watch?v=3T6U2ed3fsE]5x10 movement - YouTube[/ame]
  3. #23
    May 2006
    238
    Some pics and vid of old machine cutting 3/16 steel.
    Lots of waste
    [ame=http://www.youtube.com/watch?v=qLOSIip8ycg]3/16 steel plasma cut - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails IMAG0304.jpg   IMAG0306.jpg   IMAG0307.jpg
  4. #24
    Nov 2010
    Quote Originally Posted by dnelso View Post
    Lots of waste
    yeah, can't nrst a part like that too well!
    Machines are looking fantastic:cheers:
  5. #25
    May 2006
    238
    progress
    Finished last of the machining, alum covers for gear reduction box. Fit water tray and welded the two half's. Need to cut the drain in and weld. Still need to get the water tanks and pump. wont be too long and it should be done
    Attached Thumbnails Attached Thumbnails IMAG0317.jpg   IMAG0322.jpg   IMAG0323.jpg   IMAG0325.jpg
  6. #26
    May 2006
    238
    More pics
    more pics
    Attached Thumbnails Attached Thumbnails IMAG0336.jpg   IMAG0337.jpg   IMAG0339.jpg   IMAG0338.jpg
  7. #27
    Dec 2006
    Very nice looking table! Ive been a long time lurker but never been able to bite the bullit and start my own machine. Your machine has inspired me though and i hope to start my own build soon. Keep up the good work, cant wait to see more video of it in action!
  8. #28
    May 2006
    238
    Dragnbody
    I haven't had much time to do much writing but have tried to keep taking pics of the progress. hope to have more soon.
    Dave
  9. #29
    May 2006
    238
    got wire tracks done
    Attached Thumbnails Attached Thumbnails IMAG0346.jpg   IMAG0347.jpg   IMAG0348.jpg   IMAG0349.jpg
  10. #30
    Mar 2010
    47
    Dnelso 5 Star Tables
    Dear Dave,
    first off, thank you so much for taking all the pictures and documenting your second build. It is just flatout a w e s o m e and for sure it inspires a lot of people to go ahead into the crazy "adventure" of a CNC Plasma Built.
    I got stuck at the pont of putting the slats and now seeing your progress makes me wanna pick it up to move on and finish my build.
    My question was since I wanna do Routing and Plasma how do I reference the slats correctly in order to do precise routing?
    How do you do this? How did you do it?
    Best regards from Berlin
    - Andreas
  11. #31
    May 2006
    238
    Andreas
    Thanks for the kind words. When i use the router i put a piece of plywood over the slats and cut on top of that. Tables are ready for paint then assembly and wiring.
    Attached Thumbnails Attached Thumbnails IMAG0367.jpg   IMAG0366.jpg   IMAG0365.jpg   IMAG0363.jpg
  12. #32
    Aug 2011
    21
    Very nice builds :wee:
    any plan to add pneumatic plate maker?
    Andy
  13. #33
    May 2006
    238
    Andy
    We will be adding plate marker and 4th axis for cutting tubing
    Dave
  14. #34
    cracking build
    Really nice build-
    just what i'm looking at doing- just collating the suppliers at the moment, working out best linear rails etc,
    think i'll go for the candcnc kit for the electronics looks like a good solution for my 1st one-!
    was wondering, it looks like you've geared the steppers on your rack, is it necessary? i'm looking at a router/plasma combo so wanna get the best resolution/ reduce backlash- what ratio did you go for? and did you gear both x and Y axis?
    but v nice build you've got-
    G
  15. #35
    May 2006
    238
    G
    Both the x and y have 4 to 1 reduction. Its a good trade off for both plasma and routing. Here are some pics of the current state. One table is going together and the other is going to powder coating.
    Attached Thumbnails Attached Thumbnails IMAG0386.jpg   IMAG0387.jpg   IMAG0388.jpg   IMAG0390.jpg
  16. #36
    Dave
    looking ever better-!
    i was thinking of using a timing belt type arrangement- was that what you did- hoping it'll stay with a fairly low profile to keep everything neat-
    i like how you've kept the sliders/ rack on the sides- i figure that'll help loading sheets on etc- i'm thinking of building roughly as you have but then with a false sacrificaial bed to router on top of- maybe with a vacum hold down- which would seal the dust from the water bed-
    did you go for the dragon cut- with the 602 oz steppers from tom?
    FYI there's a guy over here knocking these out-
    your for £18k or $27k.... how much do you reckon yours has set you back-? i imagine i can get mine done for a quarter of that-!
    George
  17. #37
    May 2006
    238
    George,
    Yes i use timing belts. Here is a link to my first build you can see at the bottom of page how the belt reduction works.
    http://www.cnczone.com/forums/plasma...ld_4x10-7.html. I did go with dragon cut- with the 602 oz steppers
    Dave
  18. #38
    May 2006
    238
    worked on keyboard and mouse.
    Doesn't seem like a big deal but this was version number 5
    Dave
  19. #39
    Nov 2011
    It appears that you tapped the tube you used for the table/gantry. What wall thickness did you use? It looks to me that it is 3"x3", but not I'm not sure. I'm hoping to build a 4x8 table using a similar design starting after the 1st of the year.
  20. #40
    May 2006
    238
    The tubing is 3x3 3/16 wall
Page 2 of 9 1234
  1. Building another 5x10
    By dnelso in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-10-2015, 12:40 AM
  2. Building a 5x10 table with HBD gantry
    By mecatrodatos in forum Waterjet General Topics
    Last Post: 11-07-2012, 02:38 AM
  3. PRL motorsports 5x10 plasma table
    By Prl motorsports in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-13-2012, 09:09 PM
  4. Anyone in the UK building DIY plasma tables?
    By adscnc in forum Waterjet General Topics
    Last Post: 01-02-2012, 03:23 PM
  5. Precision Plasma LLC 2x2 Portable Plasma Tables for $1950
    By rchacich in forum News Announcements
    Last Post: 11-06-2010, 04:47 AM
