587,092 active members*
3,165 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Building new and better Wood router... electronics help requested.
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Nov 2013
    4474
    Re: Building new and better Wood router... electronics help requested.
    That's getting to be an expensive Hobby...
    Yes it is. Expense need be put in perspective though.
    as a ballpark consider:
    Mach4 Hobby license $200
    ESS motion controller $190
    Own built breakout board $100
    Ex Lease PC $300
    TOTAL $790.
    I've been using this combination for seven years, and plan on doing so for some years yet, so lets say $100/year.
    My new build mill, about a year old currently, cost about $20,000, in parts, materials , machining services etc. Lets assume I use it over twenty years,
    then the machine cost is something like $1000/year. It rather puts the Mach4Hobby/ESS/BoB/PC cost into second place.
    The next question is software. I already use Fusion 360, and have done for several years. I'm not saying its the best, or the cheapest, but I do believe its the best
    value for money CAD/CAM solution available at $500/year. I use Fusion 360 daily for work purposes, so I have little concern that I make on the deal overall.
    Now I find myself questioning whether I will use 4th and potentially a 5th axis enough to justify another $1600/year. In researching the competing
    software I find that all those whom offer 4th and 5th axis are right up there in terms of price, so while I initially though $1600/year was exorbitant
    I have come to realise it is in fact competitive. So the question is whether I use it enough, and can make money with the Machining Extensions.
    Autodesk have offered a generous discount, so I think I will try it. That will give me a year to establish whether its worth it or not.
    Craig
  2. #22
    Jul 2018
    6456
    Hi Adam - If you want an economy one box G540 equivalent heres one. I've used three of these and they have been reliable and easy to set up. I use a UC100 with them....
    https://www.oyostepper.com/goods-120...per-Motor.html Peter
  3. #23
    Mar 2010
    621
    Quote Originally Posted by peteeng View Post
    Many thanks for that Peter. I'm getting a little more comfortable with the UC100 and may go with another G540 since I already have some experience with it, but a 3rd project might also be looming for something like this unit.
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
Page 2 of 2 12
  1. Building Steel Frame Gantry Router for wood, MDF, and maybe more
    By thegadgetguy in forum DIY CNC Router Table Machines
    Last Post: 10-01-2023, 09:56 AM
  2. Building 4 axis CNC Router (wood)
    By melco in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-22-2015, 11:36 PM
  3. need help building a CNC router to carve Stone.Metal,Plastic.Wood,...
    By AlexJones in forum DIY CNC Router Table Machines
    Last Post: 01-12-2015, 04:25 AM
  4. Building new Router for Alu and Wood work
    By hive8 in forum Open Source CNC Machine Designs
    Last Post: 02-28-2013, 01:30 PM
  5. Ancient of days needs help in building low cost cnc wood router machine
    By ageofaquarius21 in forum Community Club House
    Last Post: 01-25-2006, 02:54 PM
