603,896 active members*
5,808 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > CAD posting multiple short lines instead of G2/G3
Results 1 to 4 of 4
    I am using fusion 360 and when boring a hole fusion outputs a large number of very short straight lines instead of a G2 or G3.
    Is there any way to get fusion to use G2's or G3's?
    Dec 2009
    54
    Re: CAD posting multiple short lines instead of G2/G3
    Quote Originally Posted by Forger79 View Post
    I don't think there's a way to do exactly what you want, but I'm not a Fusion 360 expert.
    When I've asked before, I've been told I need to adjust the "smoothing" settings, etc. That doesn't make a G2 or G3 for a circular path, it turns small clumps of G1s into G2 or G3 where they fit.
    In my case, the older Fanuc system I'm running cannot buffer enough blocks of G-Code for smooth operation at a reasonable cutting feed rate.
    These older machines just can't handle the volume and rate of data coming from modern CAM software.
    I program using some scripts I wrote that create G-Code from polyline curves in CAD. If I ever get that to a state worthy of sharing, I'll do so.
    Jun 2008
    1838
    What Post Processor are you using, some PP don`t support Helical Arcs which from your post is what you are looking for, yes??
    If so have a look at the attached image and the attached .nc file, all the movements are R type arcs, if your machine control will only accept I,J,K movements then that can be done as well.
    I used the Generic Fanuc Post to generate the .nc code in the Zip file.
    Here is a snippet of the code:-
    (BORE3)
    N30 T1 M06
    N35 S5000 M03
    N40 G54
    N45 M08
    N50 G00 X2.5 Y-1.
    N55 G43 Z15. H01
    N60 G00 Z2.
    N65 G01 Z1. F1000.
    N70 G18 G02 X3.5 Z0. R1.
    N75 G01 X4.
    N80 G17 G03 X5. Y0. R1.
    N85 X0. Y5. Z-0.25 R5.
    N90 X-5. Y0. Z-0.5 R5.
    N95 X0. Y-5. Z-0.75 R5.
    N100 X5. Y0. Z-1. R5.
    N105 X0. Y5. Z-1.25 R5.
    N110 X-5. Y0. Z-1.5 R5.
    N115 X0. Y-5. Z-1.75 R5.
    N120 X5. Y0. Z-2. R5.
    N125 X0. Y5. Z-2.25 R5.
    N130 X-5. Y0. Z-2.5 R5.
    N135 X0. Y-5. Z-2.75 R5.
    Hope it helps some
    Regards
    Rob
    Oct 2010
    171
    Here is a .750" diameter hole in a 1" thick piece of material. 2d boring strategy, using .04" pitch on boring, single pass.
    Posted for a Haas using the latest "pre-NGC" post.
    O09001 (bore_test)
    (Using high feed G1 F500. instead of G0.)
    (T1 D=0.5 CR=0. - ZMIN=-1.01 - flat end mill)
    N10 G90 G94 G17
    N15 G20
    N20 G53 G0 Z0.
    (Bore1)
    N30 T1 M6
    N35 S8000 M3
    N40 G54
    N45 M8
    N55 G0 X0. Y-0.05
    N60 G43 Z0.6 H1
    N65 G0 Z0.08
    N70 G1 Z0.05 F50.
    N75 G18 G2 X0.05 Z0. I0.05 K0.
    N80 G1 X0.075
    N85 G17 G3 X0.125 Y0. I0. J0.05
    N90 X0.1245 Y-0.0109 Z-0.0394 I-0.125 J0.
    N95 X0.1231 Y-0.0217 Z-0.0789 I-0.1245 J0.0109
    N100 X0.1207 Y-0.0324 Z-0.1183 I-0.1231 J0.0217
    N105 X0.1175 Y-0.0428 Z-0.1578 I-0.1207 J0.0324
    N110 X0.1133 Y-0.0528 Z-0.1972 I-0.1175 J0.0428
    N115 X0.1083 Y-0.0625 Z-0.2367 I-0.1133 J0.0528
    N120 X0.1024 Y-0.0717 Z-0.2761 I-0.1083 J0.0625
    N125 X0.0958 Y-0.0803 Z-0.3156 I-0.1024 J0.0717
    N130 X0.0884 Y-0.0884 Z-0.355 I-0.0958 J0.0803
    N135 X0.0803 Y-0.0958 Z-0.3944 I-0.0884 J0.0884
    N140 X0.0717 Y-0.1024 Z-0.4339 I-0.0803 J0.0958
    N145 X0.0625 Y-0.1083 Z-0.4733 I-0.0717 J0.1024
    N150 X0.0528 Y-0.1133 Z-0.5128 I-0.0625 J0.1083
    N155 X0.0428 Y-0.1175 Z-0.5522 I-0.0528 J0.1133
    N160 X0.0324 Y-0.1207 Z-0.5917 I-0.0428 J0.1175
    N165 X0.0217 Y-0.1231 Z-0.6311 I-0.0324 J0.1207
    N170 X0.0109 Y-0.1245 Z-0.6706 I-0.0217 J0.1231
    N175 X0. Y-0.125 Z-0.71 I-0.0109 J0.1245
    N180 X-0.0109 Y-0.1245 Z-0.7494 I0. J0.125
    N185 X-0.0217 Y-0.1231 Z-0.7889 I0.0109 J0.1245
    N190 X-0.0324 Y-0.1207 Z-0.8283 I0.0217 J0.1231
    N195 X-0.0428 Y-0.1175 Z-0.8678 I0.0324 J0.1207
    N200 X-0.0528 Y-0.1133 Z-0.9072 I0.0428 J0.1175
    N205 X-0.0625 Y-0.1083 Z-0.9467 I0.0528 J0.1133
    N210 X-0.0717 Y-0.1024 Z-0.9861 I0.0625 J0.1083
    N215 X0. Y0.125 Z-1.01 I0.0717 J0.1024
    N220 Y-0.125 I0. J-0.125
    N225 Y0.125 I0. J0.125
    N230 X-0.05 Y0.075 I0. J-0.05
    N235 G1 Y0.05
    N240 G19 G2 Y0. Z-0.96 J0. K0.05
    N245 G0 Z0.6
    N250 M5
    N255 M9
    N260 G53 G0 Z0.
    N270 X0.
    N275 G53 Y0.
    N280 M30
    Attachment 395868
    PM
  1. Deform multiple lines together?
    By twoclones in forum BobCad-Cam
    Last Post: 01-06-2017, 08:38 PM
  2. Trimming Multiple Lines
    By hst in forum BobCad-Cam
    Last Post: 01-18-2015, 01:14 AM
  3. Posting only a few lines long!
    By MaxH in forum BobCad-Cam
    Last Post: 11-26-2011, 12:26 PM
  4. Multiple lines of text
    By phatjap in forum Mach Wizards, Macros, & Addons
    Last Post: 05-06-2010, 08:34 PM
  5. convert short lines to curves
    By adscnc in forum Solidworks
    Last Post: 01-29-2010, 04:26 PM
