603,424 active members*
3,076 visitors online*
    Jul 2018
    14
    can't change spindle direction?
    In solidcam 2017, using the fanuc 2013 turning post, in this facing operation (see screenshot), changing from CW to CCW both generate M3 spindle start codes (not M4, as i was expecting). Am I not understanding how to change spindle direction?
    Jan 2012
    36
    Re: can't change spindle direction?
    Hi cryptopsy,
    Sounds like the post has been hard coded. I would check with the person you gave you the post.
    Darrin - SolidCAM USA
  1. 2D profiling - change cut direction? v26
    By robobass in forum BobCad-Cam
    Last Post: 03-24-2015, 03:56 PM
  2. Spindle enable only cycled AFTER direction change
    By zerodegreec in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2013, 06:50 AM
  3. How to change the direction of cut
    By concombrefrais in forum FeatureCAM CAD/CAM
    Last Post: 07-10-2010, 01:32 PM
  4. Change X Direction on SL-5
    By C-4 in forum Mori Seiki lathes
    Last Post: 06-29-2010, 03:35 AM
  5. How do I change the direction of cut?
    By Ironworks in forum PlasmaCam
    Last Post: 05-08-2009, 04:53 AM
