603,965 active members*
2,788 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Can't get multiple passes in v3.0
    Sep 2005
    371
    I've tried setting the cut depth to 0.5 units and the cut/pass to 0.0625 units, but I only get an output of one pass at 0.5 units.
    I must be missing something somewhere, but I don't recall having this problem with earlier versions.
    Help!
    Mar 2003
    35494
    What if you set the cut depth to -0.5?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2005
    371
    finally figured it out.
    Had to set both Cut Start to 0.5 and the cut depth to 0.5 (not -.5, tried that too)
    Then let the tool setting of depth/pass be used to determine how many times the loop had to be made to get all the way through.
    NOT intuitive at all because it doesn't make any sense! One would assume Cut start to be at the surface and the cut depth to be where you finish. To make matters worse, the graphic is misleading on the Layers tab.
    I'll REALLY be glad when a manual gets out or at least some later vids.
  1. how to change the passes in turning
    By joachim in forum FeatureCAM CAD/CAM
    Last Post: 10-17-2012, 06:46 AM
  2. Both Conv/Climb Passes on Line Art
    By MichaelHenry in forum SprutCAM
    Last Post: 09-04-2007, 03:16 PM
  3. Help creating Passes with Goaround command?
    By BulleTxMagneT in forum Dolphin CAD/CAM
    Last Post: 09-02-2007, 09:15 PM
  4. Lazycam doesn't generate "passes"
    By wadero in forum Mach Mill
    Last Post: 08-21-2007, 10:22 PM
  5. Milling: low depth passes or all the width?
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 11-03-2005, 12:57 AM
