588,138 active members*
6,690 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Feb 2007
    167
    Exclamation Cant get steps per unit right no matter what
    I have a rack and pinion driven gantry router that refuses to move accurately under Mach 3.
    I have searched for days now as to a formula that will give me correct steps per unit, but every thread has a different way that simply hasnt even got me close.
    I just chucked a dial indicator into the spindle, used the steps per unit calculator in Mach's settings to attempt to measure exact and get exact distance travels in return, nothing. After running the test, I attempted to mill a 1" square pocket but got a .9" square pocket in return.
    I have a 24 tooth spur gear with 20 degree pitch and a 1.2 inch diametrical pitch paired with a corresponding gear rack, a 1.8 degree stepper and a 10 microstepping Gecko drive. There is no way that I am losing steps as the gantry will push me across the floor or drive me around if I sit on it. My steps per unit simply arent accurate at all.
    This is my 4th CNC build (all previous have been screw driven) and its being a PITA. If anyone could shed light on this subject I would be quite greatful.
    Thanks!
    Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
    Jun 2004
    6618
    Ya gotta keep at it till you get it right.
    I did have to play with mine on my mills Z axis after I installed a timing belt. It was close on the math, but not prefect. I would up adding over 100 steps to get it very near perfect. Mach thingy will get you close, but you will have to keep adding steps and measuring to get it perfect. You may not even be able to get perfect, but still be within your tolerances.
    You must be sure that you don't have mechanical issues like backlash or loose parts of course.
    I think you will have to add more steps if it is coming up shy. Just add 50 and measure. Rinse and repeat till you get better results. Then zero in and nail it down. Once done, backup your Mach 3 XML.
    Lee
    Feb 2007
    167
    Thanks for the help, oddly enough, it seems that when steps are added the axis moves less, when steps are removed the axis moves further, definenitely backwards from what you would think. Encouraging words, I will keep pluggin' away until I get it right, unless of course someone else has some advice?
    Mar 2003
    4826
    What is the "unit" length in Mach? Inches I presume?
    Your drive gear has a pitch circle circumference of 3.7699", and it appears as though in your 'lossless system' that your motor turns 2000 microsteps per revolution. So divide the distance by the steps and you get 530.5 steps per inch. Of course, there is no such thing as half a micro step, so you'd have to round up or down, I suppose.
    Don't neglect to allow for cutter diameter when milling your 1" square pocket.
    First you get good, then you get fast. Then grouchiness sets in.
    Feb 2007
    4553
    How many teeth per inch is the rack?
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jul 2005
    2415
    Quote Originally Posted by jalessi View Post
    Does not matter. The number can be derived from the Pitch Dia and it's teeth count. You don't really need that since the important question to answer is:
    How far does the load travel in one gear rotation.
    The answer is in the earlier post. You know how many steps it takes to rotate the gear one turn.
    If there other transmission components between the motor and pinon then they have to be factored in as part of the equation.
    You will see one effect that direct pinion coupling has: Loss of resolution and torque. Up side is it will be fast enough to win you bets! You can't get better accuracy than resolution (ususally a lot worse) so you start with .001886. Microstepping is "false" resolution since it can change with RPM and is different at different speeds. Your final accuracy is a factor of all the errors times the distance.
    If you move a set distance multiple times and keep getting different values it may be a resolution problem. Also R & P has backlash if you don't keep the gear fully meshed with the rack.
    TOM Caudle
    www.CandCNC.com
    Nov 2004
    260
    Quote Originally Posted by Torchhead View Post
    Does not matter. The number can be derived from the Pitch Dia and it's teeth count. www.CandCNC.com
    That is what "Huflungdung" has calculated some circumference dia.
    Should be very close but I dont think they make standard racks with such a uneven number of linear pitch.
    May just take a physikal measurement and round to the nearest even number.
    There should be a pitch or tooth per inch value to go along with this to make a correct calculation here.
    Note you do want to know the theoretical steps per inch value.
    Before you start deviations to make up for other variables in the system.
    Good Luck
    Mar 2003
    4826
    Standard racks are based on 'so and so' many teeth in Pi inches, so it might be unusual to find a particular gear of a particular diametral pitch that would move in even inch units in one revolution ( in direct drive). That is not to say that there couldn't be some magic combo in a compound reduction that might do what you want.
    BTW, the pitch diameter of the gear multiplied by Pi gives the circumference of the pitch circle. This is the theoretical contact surface of the gear if it was toothless (a friction drive). The teeth are scabbed on just to provide good traction, they do not change the ratio at which the pitch circle rolls along the rack.
    Feb 2007
    167
    The 531 steps per unit number gives me a milled square, in particle board with a 7/32 endmill, 1/8" deep, going very slow in hopes to avoid further errors, measuring .95" x .95"
    I guess I would be okkkk with -1/16" tolerance on my machine however when I move the machine to what Mach thinks is 70" I measure 61".
    If my steps per unit were wrong then I would assume I would multiple my .05" shortage by 70 to find how short I would come up. This would give me 3.5", 70" - 3.5" should give me a physical measurement of 66.5" but as stated before I get 61".
    I must be loosing steps someplace no?
    Any suggestions would be greatly appreciated.
    Mar 2003
    4826
    You'd best show us a copy of your g code, just to be able to double check on the possible nature of the error.
    Jul 2005
    2415
    Did you account for the tool offset? The number would be to the center of the bit. If it's off then you need to get a RATIO of the error (divide the actual by the intended) and use that ratio to increase or decrease the steps per unit in the same RATIO. Work everything to 3 decimal places. You CAN have fractional steps (it averages them out over distance) and you need to use them. Take the ratio and get a number of steps to add or subtract. In this case you add if you are under the size.
    You have to measure to the center of the tool or you have to offset the cut by the radius of the cutter OR you can let the CAM program do that for you.
    TOM Caudle
    www.CandCNC.com
    Feb 2007
    167
    Here is the code:
    I promise the right bit (7/32" Endmill) is in the chuck
    G17 G20 G40 G54 G64 G90
    (2 1/2 Axis Pocketing)
    T1 M6
    (0.21875)
    G00 Z0.1094
    X0.2750 Y0.2750
    G01 Z-0.1250 F40.0
    X0.5062
    Y0.5062
    X0.2750
    Y0.2750
    Y0.1500
    X0.6312
    Y0.6312
    X0.1500
    Y0.1500
    X0.2750
    Y0.0250
    X0.7562
    Y0.7562
    X0.0250
    Y0.0250
    X0.2750
    G00 Z0.1094
    M05
    M30
    Here is the exact steps per inch that I have entered into Mach 3: 530.51647697298445256294587790858
    (Mach chopped it after a handful of digits obviously)
    This number yielded a square measuring .91" x .89" this problem just keeps getting weirder. This is a much more accurate calculation but it outputs less precision.
    Again, any further guesses would be appreciated!
    Feb 2007
    4553
    Post
    I could be wrong however the step over in your G code looks very aggressive, it may be causing missed steps.
    Jul 2005
    2415
    If the percentage of error is not constant it would indicate you are losing steps. Slow your acceleration and velocity down to about 1/2 what you have and rerun the tests. The percentage of error should be constant.
    Jul 2005
    2415
    At this point you need to not cut pockets and concentrate on getting one axis at a time calibrated. Start by marking a zero point on the table and setting the DRO to zero and running one axis out as long as you can on your table. Measure the actual. Send the axis back to zero (before you change any settings) using the MDI windows. Now find the ratio of error and use that to take your current steps per (with 3 or 4 digits of decimal) and determine the number of steps to add. Then run the test again. You should be a lot closer. Keep doing the decreasing error calulations. I use a small stylus with a point to get closer measurements.
    Once you have one axis set use the same number on the other (if the gearing is the same and you should be closer.
    After you have the machine so that it is dead on at a long move then you can start running your small tests.
    If you can't get repeatability then either you have serious backlash (poor gear mesh), something is loose or you are losing steps. Slowing the tuning parameters down will confirm the last possiblity
    Feb 2007
    167
    Thanks again for the suggestions. It would seem to me that a formula would prove much more accurate than measuring with a measuring tape of 80+ inches. Why the formula yields goofy measurements though is beyond me.
    I can assure you that the step over is by no means aggressive. It is running at 16,000 RPM, an 1/8" deep and 6IPM. Ssuuppppeerr conservative to avoid any lost steps.
    I will try your advice Torchhead and get back to you shortly, thanks again, appreciate it!
  17. #17
    Jul 2005
    2415
    As in most formulas the fact there are tolerances and variations in each number makes them more ballpark than exact. This is one of the shockers to new engineers that instead of doing pages of math to do circuit design (especially with analog circuits) it's much quicker to have a grasp of the approximations and work around a range of common values. There are inherent errors in everything from the rotor position in the motor to the backlash in the gears.
    Tom Caudle
    www.CandCNC.com
  18. #18
    Feb 2007
    167
    Well over 60" in X I am off 1/16 and over 40" I am off 1/32", "tape measure tolerances" are fine for me. Now when I run my pocket I get a .95" x .95". Still doesnt quite make sense but this is the closest ive been.
    Shown below is a screen shot of Mach, units/min are showing ~80IPM, im seeing no where near that, more like 30IPM. Why would it be showing me something different? Thanks
  19. #19
    Mar 2003
    35538
    Did you close and restart mach after changing settings?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  20. #20
    Mar 2003
    4826
    I did a backplot from your gcode, and then offset it by 7/64 (ie., the cutter radius, and the square comes out to .950 x .950
    Always check your 'rithmatic
Page 1 of 2 12
  1. difficulty setting steps per unit in mach3
    By Josh Leber in forum Machines running Mach Software
    Last Post: 08-04-2009, 10:57 AM
  2. Steps per unit calibration problems
    By idtkid in forum Mach Software (ArtSoft software)
    Last Post: 05-12-2009, 04:48 AM
  3. Mach 3 Configuration Steps per unit
    By andycorleone in forum DIY CNC Router Table Machines
    Last Post: 11-22-2008, 02:55 PM
  4. Steps per unit is all messed up???
    By mwalach in forum Mach Mill
    Last Post: 02-18-2007, 06:50 PM
  5. Set-up / Steps per Unit / Threads per Inch
    By adda in forum Mastercam
    Last Post: 01-15-2007, 11:29 PM
