They look like this: Amana V-Groove Router Bits
All the credit goes to jsantos for making the g-code files, and Hyrum R for hosting the files on his web site. The original DXF file came from the Vectric forum. All my "routy friends" have been happy since they were posted.![]()
CarveOne
(who makes terrible puns)
CarveOne
http://www.carveonecncwoodcraft.com
I finished the 30" calendar this morning and hung it on the wall with two screws and notched hangers. This one weighs 26 pounds.
The remainder of the day was spent working on the Super-PID modifications for the Porter Cable 7518 router.
CarveOne
CarveOne
diyengineer-
Here is a drawing of the method that I suggest.
The ID of the chain is 4.5" with a 6" spacing between the links. A 4" dust collection hose can be run through the chain quite easily this way.
The chain is designed so that it's bend circumference is limited to 24", however, this can easily be modified.
I plan on using this method rather than CarveOne's method because I have literally no available room above my machine to run a dust collection hose. This sort of chain eliminates any droop from gravity that one would normally see with a long flexible hose. The advantage is that it makes a straighter run of the hose which improves airflow.
The downside is that this method is very complicated compared to CarveOne's zip-tie and staple method. Oh how I wish I had 10ft ceilings!
HTH,
Jay
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
CarveOne,
That calendar really fits that space well. Now you just need a Mayan and an Incan calendar hanging next to it and you will be set!
Jay
CarveOne
I wish my ceiling was 10 ft also, but it's just 8 ft. On a machine as long as mine the hose is a problem. The stick that it is tied to is just there to keep the hose from dragging around on the table. I changed some of the hose to 4" drain pipe and elbows to eliminate the drooping horizontal hose that was under the ceiling.
CarveOne
CarveOne
C1, the one I have been fiddling with is just part of the Mayan calendar.
Unfortunately if you google mayan calendar you get that aztec one in the results as well. Two different things though. Never seen the Inca one.
Link: BmpBender.zipI still have the file. I'm at work right now so I'll post a link to it when I get home in the morning.
Many thanks Tulsaturbo![]()
From my reading of various websites the two calendars are closely related, with the Mayan version being older. The Mayans also had a pyramid style calendar and the Aztecs used the round style. (Pyramids are not very portable and difficult to hang on the wall.)
When looking at sites about Inca calendars they show the round calendars and some other types of observation sites. It's all very confusing to me. It seems to have something to do with the number of days in a one year cycle and how they were represented on the calendar in symbolic form. It appears that unless you understand how they work in detail you wouldn't know one round calendar from the other, and I'm going to leave it at that. They all look pretty when v-carved.
CarveOne
CarveOne
Hehehe, I agree completely with your statement CarveOne!
When I said that you should have all three, I was saying that from my very loose knowledge base about the subject. My grandmother was a professor of Central and South American ancient civilizations, so I am quite used to seeing all of this images. After a while, they all blend together!
I'm sure that I can ask her which is which, but she may attempt to explain the differences in the utmost amount of detail; something that I frankly would not look forward to listening to. An amount of detail is fine, but not the extent that I know she tends to explain things. I guess that comes from being a professor on the subject.
From what I understand, and this may be completely wrong, the Inca calendar counts 365 days, the Maya calendar 260, and the Aztecs have two calendars (a 260 day and a 365 day).
All of them are round and all of them have similar glyphs depicted. So to the untrained eye, they all look the same... which is good enough for me!
I really want to have a go at making a working, moving version of one of these calendars. I think that would be really cool to hang on a wall.
Jay
Back in Arbo's post #2209 I had noticed that the points collide. I think it is spaced for the outer perimeter of the large circle of symbols. Then the small center circle goes around inside the middle size "gear". At least that's how I see it depicted in tutorial videos online. There is an online clock gear utility that may help with the mechanical layout of the CNC cut parts.
CarveOne
CarveOne
CarveOne,
That is exactly what I was thinking.
I was planning on using one of these:
Continuous Sweep High Torque Movement - Clockparts.com
and somehow linking the hour hand in to the day gear. I'm think that I would make a simple planetary gear system. The hour hadn would be the sun, and it would have a corresponding planet that was then linked to the Day indicator. And the Month indicator would act as the ring gear for the system.
It seems simple enough. The only difficult part is converting 24 hours in to one day, and that shouldn't be too hard.
I'll see what I can draw up tonight.
Jay
