Magnitude Engineering is offering 16 position standard cat 40 tool rack for Haas CNC mills. Rack is laser cut and precision formed from .080" thick aluminum and has four hanging tabs (13" wide) to mount directly to the slots on Haas machines. Can also be used with any cat 40 mill as a benchtop rack. Top is angled 15 degrees for easy access to all tools. Full height front and side flanges protect tapers and pull studs from stray chips. Approximate overall dimension: 13" W x 12" D x 7" H. Machine and tools are shows for reference only and are not included.
Magnitude | Products
