Does anyone have a way to address this issue easily? In the past I have broke the edge into 2 lines roughly 1/2 the diameter of the cutter to keep the cutter off the edge but its many steps and very cumbersome.
Thanks!
Thanks!
We need more info. Do you mill out what you can first? then go in with the angle mill?
I apologize for being so vague. Im talking about the 0.01 chamfer around the outer perimeter of each feature. BobCAD has a chamfer strategy that works quite well like you see on the Z0 plane of the part I have pictured. At the lower Z plane the chamfer mill slams into the edge of the wall. Ive tried some simple thing like using a negative value for the parallel lead-in/lead out option and substatuting with a fake larger cutter but no success.
I've always created sketch profiles for chamfers like this on bobcad. But it is a pain, so I avoid it.
Recently I started to play with fusion 360, and last night I tried their 2d chamfer out. It was a chamfer that ran very close to the edge of a sidewall. And Fusion kept refusing to cut along the edge of the sidewall... I finally changed a setting, that set how close you would let the tool get to a edge, and it completed the chamfer. This is a great way to handle chamfers, maybe bobcad can do something similar?
Work: Hurco VMX42/VMX50 - Shopsabre 4896 - Bobcad V4 4axis pro
Home: RF45 with Ajax CNC Controller - Bobcad V27 3 axis pro
Yes MikeC8 - That is basically what I am asking. I know Fusion would do offset to miss the wall and was (still am) hoping that there was a similar way in BobCAD to do that. The chamfering strategy works great except for this.
I have never had any trouble with a chamfering any part if I want to stay off the edge I just tell it to do so from the library. Wish I had your file so I could look at it fast.
See attached. Thanks
Try the attached, just use the extract edge utility before you chamfer the model and then just use the "Modify Entity" to change the start/end points and that is what you need to select for the chamfer, it`s quite quick once you get the idea![]()
Sorry, that`s all I have
Obviously the smaller tool the closer to the wall you can get![]()
I have a strategy to cover this issue but it may not be much faster than what you are doing. I can detail it with an example file if you are interested but the gist of it:
I program the feature without regard for the cutter gouging the wall or corner. Once I have my "Depth" and "Cutter Position" tweaked (I don't really tweak them, I use the same settings/DMS 99% of the time) I know how far the centerline of the cutter is offset from the selected geometry (for a 45 deg chamfer it is simply "Cutter Position" + "Depth/Width" + 1/2 of small diameter of the tool). Figure your tool radius and subtract the value you just calculated from that.
This is your necessary offset to avoid walls and corners. I would use the "Offset" function on anything I wanted to avoid and use that geometry to clip the Chamfer geometry. It sounds complicated but it takes me about 1 minute to do both ends of an open ended chamfer. Screenshot attached but it's sort of backwards, I started at the bottom. Took me 3 minutes including finding an example file and putting together the screenshots.
Always looking for a better way myself so I hope the suggestions keep coming.
