603,896 active members*
4,735 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Changing/resetting the table position during a tool change?
    May 2008
    Cool Changing/resetting the table position during a tool change?
    I've got a Mori Accumill 4000 and I'd like to change the location of the mill table during tool changes. The stock tool change position setting puts the mill table directly under the tool changer arm during tool changes and if I have a tall part to cut with long tooling, I run the risk of crashing the tool into the part.
    Any suggestions?
    Thanks,
    Jim
    Jun 2006
    440
    Quote Originally Posted by Jim Ster View Post
    Any suggestions?
    Thanks,
    Jim
    We use a sub program call prior to tool changes on our FM-2 in our case it is program O0098.
    example
    <NC CODE>
    M98 P98;
    Tnn;
    M06;
    <NC CODE>
    :0098(TOOL CHANGE POSITION)
    G91G28G0Z0.0M9
    G30X0.Y0.
    G80G49G40
    M19G90
    M99
    Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
    Mark Twain
    Jul 2008
    Hello! thanks.
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. tool change position on a mazak nexus mill 640m
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-03-2008, 05:15 PM
  3. Sabre 500 acarmatic 850sx tool change position
    By foxsquirrel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-12-2008, 04:28 AM
  4. Sabre 500 acarmatic 850sx tool change position
    By foxsquirrel in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2008, 02:51 AM
  5. Swiss Lathe, Tool Change Position
    By John3 in forum MetalWork Discussion
    Last Post: 08-07-2007, 12:46 AM
