603,800 active members*
3,665 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > "Chinese" spindle minimum speed
Page 2 of 2 12
Results 21 to 40 of 40
  1. #21
    Sep 2015
    21
    Re: "Chinese" spindle minimum speed
    Quote Originally Posted by isakl View Post
    It took some time, I was busy on writing a program to connect to the VFD via the rs485.
    Eventually I would like to control the VFD via the emc2 program.
    Here are some of my parameters (i hope i don't miss some of the important ones)
    A003: 400
    A004: 400
    A041: 0
    A042: 8.5 (Manual torque boost value)
    A043: 1.5 (Manual torque boost frequency adjustment)
    A044: 0
    A045: 100
    A061: 0
    A062: 0
    A085: 1 (Operation mode selection), not sure if that's necessary.
    A086: 70 not sure if that's necessary.
    B082: 5
    B083: 3.0
    B086: 60.0
    B092: 2
    C149: 100.0 (relay turn off delay) Used for coolant pump activation.
    H003: 7 (2.2KW motor)
    H004: 2 (poles)
    I know this an old thread, but I would like to get "your thoughts and input" ( from others as well) if possible on running my 2.2 kw water cooled spindle.
    I have a 3hp VFD Huanyang... will the above parameter work on this type of VFD?
    Are my expectations reasonable listed below:
    I'm working on a 4:1 gear reduction drive for it to help with powering low speed RPMs.
    I really don't need 20,000 rpm.so 4:1 ratio (5,000 RPM tops) is good enough for me which will also allow me to run much slower RPMs..
    I'm hoping that I'll be able to tap aluminum 3/8" UNC at about 300 RPM.
    Do you think from your experience that is reasonable to expect that from this 4:1 drive setup?
    Any advise or suggestions are greatly appreciated.
  2. #22
    Jan 2005
    15362
    Quote Originally Posted by Hirudin View Post
    Oh no... I was hoping someone would come here and say "I run mine all the time at 1000 RPM without any trouble". Instead I find out that maybe it isn't a good idea to plunge straight down? My CAM program (RhinoCAM) will ramp in for the first contact with the material, but as far as I've seen, every subsequent drop in Z is straight down.!
    This is an old thread
    It's not going to have any torque at 1000 RPM you can most likely stall it with your hand, once you stall it in most cases you need a new spindle or both VFD and Spindle
    That being said, there is one manufacture that can go down to 3000 RPM to 24,000 RPM
    Mactec54
  3. #23
    Jan 2005
    15362
    Hi Hirudin,
    Sorry for the late response.
    I've just received my new 2.2KW water cooled spindle.
    Before purchasing I had exactly the same dilemma, as many times when machining steel, or even aluminum with large diameter HSS tools you need rather low RPM.
    Now I have this spindle, and a Hitachi X200 inverter.
    The very first tests that I did was seeing at what lowest RPM I can run it.
    To my amazement, it was no problem at all running even it as low as 200RPM.
    At first it had very little torque at this speed. After playing with some parameters of the inverter, I managed to throw the full 10Amps while turning 200RPM.
    Of coarse it will start to heat up rather quickly, but this is the advantage of water cooling. If you have sufficient pump and radiator, there is no problem.
    I have about 1 liter water reservoir, and a small radiator with a fan.
    I can run it at 200RPM, 10Amps for more than half an hour. It becomes pretty warm to touch, and the reservoir temperature climbs to about 45 centigrade, but that's the hottest it gets. I can continue to run it, and it won't get any hotter. I think that putting a bigger radiator would reduce the temperature even further.
    I tried to mill steel (low carbon) with 3/8 carbide endmill, 0.1mm DOC at 800RPM. It ate it without any difficulty.
    Aluminum is even better.
    This is an old thread but worth replying
    That is not going to last very long if you keep running at that speed, the overheating will destroy it in no time
    Mactec54
  4. #24
    Jan 2005
    15362
    Quote Originally Posted by cnc-xray View Post
    Sometimes old threads are worth a reply
    The Parameter above are for anyone to use at the risk of damaging there spindle and VFD Drive
    Using a 4:1 reduction should work well I don't know about the tapping though, if it stall you will take out the spindle, stalling is the main problem with these spindles
    Why don't you thread mill your holes much better than trying to power tap them and will do a better job, you could do this without the reduction at 8,000 RPM to 12,000RPM
    Mactec54
  5. #25
    Sep 2015
    21
    Thank you for your response.
    Please note that it seems that isakl got his to work for a long time at very low speeds "without" a reduction drive.
    Thread milling certainly is an option and I would need to go that way for larger taps. I've done lots of that with bigger tap holes on bigger machines.
    The 3/8 UNC is the largest that I was thinking of using power tapping with this spindle and I could limit to smaller if it's still not a reasonable option.
    I was hoping that a 3/8" tap would break instead of stalling the spindle which I think should be the size limiting factor for power tapping. 3/8" might still be too big for this spindle setup, but most of my tapping will be much smaller which makes thread milling probably a little dicey.
    With that in mind...
    I'm willing to give it a try if there is any chance that it could work for small hole tapping (max tap size to be determined).
    In your opinion:
    What would be the best lowest speed "parameter settings" for my drive set as was explained taking into account the 4:1 reduction?
    What do you think would be the largest small tap that the spindle would be able to break at low speeds before stalling?
    I do a lot of mixtures of 1/4"and M3 tapping on other machines, so I need to figure out where thread milling becomes the only option for this setup.
    I definitely agree that stalling the spindle should not be an option.
    Can you give your thoughts on why isakl got his to work for a long time at very low speeds "without" a reduction drive?
  6. #26
    Jan 2005
    15362
    In your opinion:
    I'm sure his spindle did not last very long, at 200 RPM, they don't like over heating which he was having and if you look at his parameter settings he was not running at the speeds he said he was so some Bs just right there 60Hz was his lowest speed Parameter in the list he posted which is 4,000 RPM
    Mactec54
  7. #27
    Sep 2015
    21
    OK... With a 4:1 reduction what is the "slowest spindle speed" you would suggest to still get enough torque to break a 3 flute 1/4" machine tap.
    Could you provide me with the correct parameter settings for the VFD I'm using?
    From some post I read... it looks like you have a lot of experience with these Chinese Spindles and VFDs.
    Here is some info on my VFD:
    Type:YL620-A-2.2KW 220V
    Input: AC 220V 50/60HZ
    Output: 10A 4.0KVA
  8. #28
    Jan 2005
    15362
    Every VFD Drive is different most spindles are the same, I don't think it would have enough torque to break the tap at any speed , the minimum speed for most of these 2 Pole Spindles is 6,000 RPM = 1500 RPM with your reduction you can only but try and see what happens, Ideal you rollform threads in aluminum then you have much better thread strength, to rollform you need a different type of Spindle Motor which would be 4 pole low RPM although 1500 RPM would be ok for 1/4"-20
    How are you going to synchronize the Spindle and Feed to rigid Tap
    Mactec54
  9. #29
    Sep 2015
    21
    That is my plan to synchronize the Spindle and Feed for rigid Tapping, but have not yet worked out the details for that.
    Do you have info or recommendations on that as well?
    I know some guys do 1/4" tapping at 3000 RPM+ but I need to build myself and the machine up to that first!
    I posted the info on my VFD on my previous post to help with the correct parameters needed, and again... I'm willing to try.
    Greatly appreciate your input and help.
  10. #30
    Jan 2005
    15362
    Yes Taping at 3000 RPM is very doable, this is a very different machine than a Hobby built machine
    You need an Encoder mounted on the spindle that can handle your max RPM and a control that has an Encoder input for spindle control and can do rigid Tapping or threading
    Mactec54
  11. #31
    Sep 2015
    21
    The machine I'm working on is more of a mill than a router, with an automatic 12 tool changer I designed. It is very rigid...
    I've looked at 6000 rpm encoders and it seems that they are available for less than $200 (still need to do research on that).
    I still would like the parameters you would suggest for my application and VFD type.
    Can you help with that?
    Again... here is some info on my VFD:
    Output: 10A 4.0KVA
  12. #32
    Jan 2005
    15362
    Output: 10A 4.0KVA
    What are the motor spec's you can only set the VFD to the motor spec's
    If your motor can run higher than 6,000 RPM then that encoder would not be much good
    You need to start your own thread
    Mactec54
  13. #33
    Sep 2015
    21
    I would start a thread but I only now need the parameters for the VFD
    I think I can work with 4:1 ratio at 6000RPM = 1500RPM Lowest Spindle Speed
    Motor:
    80x200 2.2KW 220V 8.5A 400HZ Water Cooling
    They Claim: Speed:0-24000rpm at 0-400HZ
  14. #34
    Jan 2005
    15362
    Motor:
    They all run from 0-24,000 they just missing the 6,000 minimum speed you may be able to go lower depending on who the manufacture of your spindle is I have some that will run at 3000 RPM but these are higher torque and a different built motor than the normal
    The VFD Drive you have has not been as good as some of the other VFD Drives I will look and see what I have for that Drive I have done there Parameters before
    Mactec54
  15. #35
    Jan 2005
    15362
    Motor:
    This should get you started
    Mactec54
    Spindle Cable IGUS CF6-15-04 PH 401-438-7270
    Huajiang VF Drive
    YL 600/620 220 2.2Kw Water Cooled
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P06.01=8 ( Acceleration Adjustable )
    P06.02=8 ( Deceleration Adjustable )
    P0700=400
    P07.08=0
    P11.01=220 ( May be 2 for 220v if you can't change it to 220 )
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    Mactec54
  16. #36
    Sep 2015
    21
    Mactec54
    Huajiang VF Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    Thank you very much Mactec54
    This is very helpful
  17. #37
    Sep 2015
    21
    Mactec54
    Huajiang VF Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    I just compared these parameters to an old post showing parameters you provided for allaces for the same VFD = 7200RPM and they seem to be the same as the ones you provided to me for 6000RPM.
    I'm including the allaces parameters below...
    Please advise.
    Also... what parameter(s) actually define the minimum RPM?
    Re: Spindle Recommendation
    Originally Posted by allaces
    Do you have the parameters for me?
    Yes I do have them ready, but make sure all your wiring is correct before you try and run it and enter the Parameters
    Parameters listed will give you 7200 RPM
    I would like you to verify the wiring with photos you only get one shot at this so you want it to be right
    Mactec54
    Huajiang VFD Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
  18. #38
    Jan 2005
    15362
    Please advise.
    Mactec54
    Huajiang VFD Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    P00.09=100 for 6000RPM
    P03.08=100
    P03.09=400
    Mactec54
  19. #39
    Sep 2015
    21
    P03.08=100
    P03.09=400
    Thank you mactec54... I feel better now.
    I have a Tapmatic Tapping Head that I use on my drill presses, but I never thought of using it this way.
    https://www.youtube.com/watch?v=cm2gZh5k4F0
  20. #40
    Apr 2019
    9
    @isakl
    Can ou write something about the life of your spindle?
Page 2 of 2 12
  1. Chinese Spindle, "Germany" bearing mystery solved!
    By Tim Nye in forum DIY CNC Router Table Machines
    Last Post: 06-22-2015, 09:26 AM
  2. Looking for some "high"er speed spindle ideas for my bf20 clone
    By GreatNorthGnome in forum Benchtop Machines
    Last Post: 06-28-2014, 08:57 AM
  3. Fagor error code " No Spindle Speed Value "
    By Hirro in forum Fagor Automation
    Last Post: 06-20-2013, 02:32 PM
  4. Yet "another" Chinese Spindle Question
    By Bob La Londe in forum Maintenance DIY Discussion
    Last Post: 02-14-2012, 11:31 PM
  5. Chinese Spindle " problems"
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 02-05-2010, 03:46 AM
