603,799 active members*
2,377 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > chnc wont go into jog or mdi mode and no zero return
Results 1 to 4 of 4
    Jul 2009
    13
    I have a chnc when I fire the machine up it wont let me home machine or get into mdi,jog. I think it may have something to do with the collet closure as when i open and close, the open button light up right away but when I hot close takes about 6-7 seconds before lights up. I can move x and z with handle mode but thats it. please help with any suggestions.
    Mar 2010
    1852
    Quote Originally Posted by snascar2424 View Post
    The collet close delay is normal, it's called the collet closure delay and can even be changed or set in a program.
    What control do you have on your machine? Otherwise we can't help you.
    Mikr
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Jul 2009
    13
    the control is a gn10. I have got a repair guys out but the wiring does'nt match up so we are dead in the water until we get a reply from hardinge.
    Mar 2010
    1852
    Sorry, I have a Siemens 810T so not the same. For those following this you need to give more details if you want help. Did you just get this machine, did it ever home, etc.
    When I got my machine it had a bad emergency stop switch that gave me fits and sightly corrupt software. The bad E-Stop switch was probably the reason the machine was put up for sale, as it would just go on and off on its own, causing all kinds of issues. After fixing this minor issues, I have a really sweet machine.
    The E-Stop switch that was bad, (dirty), was the lower left side one, it is always getting wet and such, that's the one to check and keep that area clean.
    Mike
  1. Replies: 4
    Last Post: 02-10-2016, 04:30 PM
  2. ZRN (zero return mode) in fanuc 0m
    By PRIOR666 in forum Fanuc
    Last Post: 11-12-2011, 06:12 PM
  3. mach 3 on new PCNC770 wont go out of demo mode with license installed...
    By Smokey911 in forum Tormach Personal CNC Mill
    Last Post: 10-12-2011, 03:15 AM
  4. Quill wont return to its top position
    By JonnyD in forum Bridgeport / Hardinge Mills
    Last Post: 06-20-2011, 02:21 PM
  5. CHNC 1 Hold Single Block / in Auto Mode???
    By jeffserv in forum Hardinge Lathes
    Last Post: 06-11-2011, 05:08 AM
