603,797 active members*
2,253 visitors online*
    Jun 2013
    4
    Choosing between two stepper motors
    I'm looking to buy stepper motors for my diy CNC, and I doesn't really understand all the specification.
    So I required a little help from you.
    Which one of the two linked here is the best ? why ?
    NEMA17 HI Torque 50N CM Stepper Motor 1 8deg Reprap 3D Printers CNC Robotics | eBay
    Black Nema 17 Stepper Motor HI Torque 3D Printing CNC | eBay
    Thank you,
    Mar 2003
    35494
    It depends entirely on the application. One might be better for one machine, and the other might be better for a different machine.
    If the torque ratings are equal, in most cases, the motor with the lower inductance will usually be the best choice.
    Unless you're building a 3D printer, both of those will likely be too small.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2013
    4
    Thanks for your response.
    It's a very small CNC (60cm*60) and not very heavy, so there is no real difference with a 3d printer
    Torque seems to be around 50N.cm for both, for nema 17 type motor, I couln'd find stronger ones.
    So, if I follow your advise, I should go for the smaller inductance one ?
  1. choosing drivers stepper motors and power supply
    By denningt in forum Community Club House
    Last Post: 11-05-2013, 06:05 PM
  2. Choosing controller and motors
    By kaar3l in forum Stepper Motors / Drives
    Last Post: 10-11-2011, 06:16 PM
  3. Choosing Stepper motors oz/in...
    By mrbaseball in forum DIY CNC Router Table Machines
    Last Post: 05-28-2011, 12:49 AM
  4. Choosing motors and the machines that fit them
    By Doggitter in forum Servo Motors / Drives
    Last Post: 02-17-2010, 03:50 AM
  5. Help with choosing steppers motors
    By Biggermens in forum Stepper Motors / Drives
    Last Post: 10-22-2004, 04:23 AM
