603,383 active members*
3,479 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Citizen F20 Over-Sized Collet System?
    Mar 2007
    168
    Does anyone know of a kit which would allow you to run 25mm material on an F20? I just recently purchased a 1984 F20 and have heard that there is such a kit but I havent been able to find it. I think that they share the same castings and everything. Would it be as simple as changing the spindle liners? Thanks.
    Feb 2008
    267
    Quote Originally Posted by yoopertool View Post
    ... Would it be as simple as changing the spindle liners? ...
    I doubt it.
    If such a kit exsists, your local Citizen distributor should be able to help.
    If they're reluctant or unsure, then I'd contact MCC New Jersey.
    Someone there should be able and willing to assist you.
    Good luck!
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    Mar 2008
    443
    If they are built from the same castings in the same way that an L25 is to an L32, it's an easy switch.
    You'll need a collet closer and push tube, but the bigger expense is in replacing the rotary guide bushing unit to accept the larger diameter guide bushings. Also, there may or not be a way of increasing size of the sub-spindle, vut yu usually won't need to because it's common to be doing the pick off to a diameter smaller than the maximum stock size.
    Call Citizen Machinery America and they can give you all the part numbers you need.
  1. Citizen Adaptive Collet and SMQ Brass?
    By Suisse in forum CNC Swiss Screw Machines
    Last Post: 11-02-2009, 06:38 PM
  2. Re-grinding spindle for new collet system?
    By Stuff-Builder in forum Uncategorised MetalWorking Machines
    Last Post: 12-19-2008, 12:43 AM
  3. Re-grinding spindle for new collet system?
    By Stuff-Builder in forum Knee Vertical Mills
    Last Post: 12-18-2008, 07:09 PM
  4. Where to buy bits & collet system
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 12-15-2008, 05:16 AM
  5. CITIZEN E-serie (MITSUBISHI system)
    By subalb in forum CNC Swiss Screw Machines
    Last Post: 01-22-2008, 04:16 PM
