587,324 active members*
3,529 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Closed file without saving G-Code!!
    Nov 2008
    47
    Hi Folks,
    I have had Turbocad 14 Pro Platinum, with the CadCam plug in for some time. I've been with TC since V7 Pro and have loved it. So when I got into CNC, it was only natural to get the TCC plug in, and it's been a real disappointment to say the least! It's clunky "someone said", poor documentation among other things...well my problem.
    I closed a file I was working on without saving the G-Code, assuming all my setting like machine setup, tools, tool paths, etc... would be saved with the file also. But when I reopen the file all my setting are gone!! The part is still there showing the cut part with the tool paths showing but that's it. No machine setting or anything... just a blank Cam window. Is there anyway get this info back or am I going to have to start over??
    I see a lot of threads about a post processor for TCC and Mach 3 but no real answers to the questions. My self I just save the G-Code to notepad and load it from Mach 3.
    Any help is appreciated,
    Curtis
    Feb 2008
    26
    similar problem
    My problem is I saved g code then the drawing, packed up and went home, came back the next morning and g code won't open with tcad file that has all the tool paths over it, even the deleted mistakes I hoped not to deal with agian
    (they still won't delete)(I am thinking of moving the drawing to a new section on the grid).
    so I loaded the g file it showed on the drawing about 100 time smaller than the original, and the tool data and operation tree all gone.....
    Help drowning here
    John
  1. trouble saving rhino file to useable DXF
    By bradyfb in forum Rhino 3D
    Last Post: 03-31-2009, 02:26 AM
  2. Saving a file
    By bjm323 in forum Mastercam
    Last Post: 11-23-2008, 06:22 PM
  3. Saving file
    Last Post: 10-16-2008, 12:05 AM
  4. Saving a File
    By utahnorton in forum Centroid CNC Control Products
    Last Post: 12-29-2006, 04:10 AM
  5. Saving a Text file?
    By Scott V in forum BobCad-Cam
    Last Post: 11-24-2004, 03:27 AM
