603,822 active members*
4,606 visitors online*
Page 2 of 5 1234
Results 21 to 40 of 89
  1. #21
    Feb 2010
    I assembly mechanical parts already.
    I needed 4 month to finish this project.
    Now the most scary parts, electronics.
  2. #22
    Jul 2008
    922
    beautiful!
  3. #23
    Mar 2004
    1306
    Wow. Amazingly ambitious project. Respect.
    How are you doing the spindle drive?
    Regards,
    Mark
  4. #24
    Nov 2005
    264
    beautiful work!
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
  5. #25
    Mar 2006
    489
    Looks awesome man! How much does it weigh? What type of tool turret are you planning? Are you going to have a tailstock also?
    Paul
  6. #26
    Jul 2007
    1602
    Very nice lathe. It will be interesting to see it making chips.
    I have a question. I noticed that the reference edge for the linear rails is a removable strip. Is there a particular reason you did it that way as opposed to simply machining an edge into the casting?
    bob
  7. #27
    Feb 2010
    Teyber12,
    Thanks.
    Mark,
    Spindle plan to be driven by 3HP motor & inverter, not bought yet.
    Still thinking, to use that or AC Servo ( to do threading)
    Enraged,
    Thanks.
    Paul,
    Weight about 150kg.
    It will be vertical gang lathe without tailstock
    Bob,
    The reason for reference edge for the linear rails made from removable strip,
    I can adjust easily by grinding the hardened steel insert, instead fix cast iron.
  8. #28
    Feb 2010
    Good progress, Today I tested already the most scary parts, electronics.
    After few times switch back the parts, make some smoke, finally tested already. But not satisfy yet, add some more electronic parts on the pcb.
    :banana::banana::banana:
  9. #29
    Feb 2010
    Here the PC connection plan.
    PP1 = Charge Pump
    PP2 = Step(Pulse) X
    PP3 = Dir(Sign) X
    PP6 = Step(Pulse) Z
    PP7 = Dir(Sign) Z
    PP10 = Limits
    PP14 = Spindle Speed
    PP15 = EStop to PC
    Pp16 = Spindle CW
    PP17 = Spindle CCW
    PP18-25 = Ground
  10. #30
    Quote Originally Posted by Monkey King View Post
    Mark,
    Looking great. I'm sure you know this but you can do threading without a servo controlled spindle by using a sensor to give a spindle index pulse.
  11. #31
    Feb 2010
    Yesterday I bought already Toshiba 5HP Inverter and 4HP Motor.
    Already tested H21A3 Phototransistor optical interrupter switch for spindle index pulse. Plan to use PP11 input as Index.
  12. #32
    Jul 2008
    199
    Hi Mark,
    I use cnc kneemill.
    monkey king,
    those doors are 70's indian style doors. What is your location. btw wonderful build. Are you getting tool chaters using 15mm lm guides? any sample of a turned part on your lathe?
    jasminder singh
    It is better to die for something than to live for nothing.
  13. #33
    Jun 2006
    474
    Monkey King,
    Very Nice work,
    Chich
  14. #34
    May 2004
    162
    Talking work
    AWSOME!!!!!:banana::banana::banana::banana::banana :
  15. #35
    Feb 2010
    Jasminder singh,
    Linear slide by HIWIN 15mm.
    Until now not finish yet, last week I buy pulley and found out that that pulley out of balance. So I make myself. It takes time to finish. Be patient.
    Chich,
    p38nut,
  16. #36
    Feb 2010
    Today I tested the spindle.
    Until 3000 rpm the spindle is smooth. but reaching 5000rpm, the spindle is hot after 5 minutes, then the spindle getting heavier to spin, even I put many oil already(I made oil input & output hole for each bearing). I think the spindle got thermal expansion(Spindle body made from cast iron, but the spindle itself made by steel).
    Still thinking to use water cooling on spindle body or change the plan to 3000 rpm.
    Any suggestion?
  17. #37
    Sep 2005
    1198
    Why you should go hi rpm for lathe? What motor RPM basically? If you go that hi, maybe use servo motor spindle like the one on cnc lathe.
  18. #38
    Jul 2008
    199
    Any suggestion?
    money king,
    water cooling is the best way. I just watercooled my 3A stepper drivers that were getting very hot. But after water cooling they run at room temperature.
    But the problem you can face with your spindle cooling is" the circulating water will get too hot in couple of hours".
    But for a lathe i guess 3000 rpm should be the limit, specially if it is a small lathe. Btw what you want to turn on 5000 rpm? the bearings will be ruined in months?
    I guess sticking to the lower rpms is better option for now. in the future if you are not satisfied with the performance you can upgrade to 5000.
    Actually, i am just waiting for your lathe to make chips. plz Do it fast. For water cooling, you may need a huge watertank for watercooling or a chiller system if you have couple of letres only of circulating water.
    any pics of the spindle? motor?
    jasminder singh
  19. #39
    Jul 2008
    199
    Any suggestion?
    another news, the bearings you are using are limited to 4500 rpm according to skf.
    http://www.skf.com/skf/productcatalo...=3&startnum=10
    check it out
  20. #40
    Feb 2010
    asuratman,
    because I need 5000 rpm to cut material to archive mirror finish.
    I bought motor 4 HP 2880 rpm at 50 Hz.
    jasminder,
    2 month ago I made chiller by using 2HP air conditioner outdoor unit and made a stainless steel water tank to cool down my miling spindle. This what I'm thinking to use on this machine. For the bearing, It live should be long, since max speed is 6000 rpm, and I'm confirm about alignment of the bearing, since I made the spindle body & spindle by 1 time setup grinding.
    But I'll make the lathe run first using 3000rpm and I'll upgrade next time.
Page 2 of 5 1234
  1. King 7x12 Lathe
    By aarongough in forum Benchtop Machines
    Last Post: 01-04-2013, 11:27 PM
  2. Has anyone ever made their own lathe?
    By sanddrag in forum Mini Lathe
    Last Post: 10-30-2011, 04:58 PM
  3. Polishing Aluminum using Burr King Vibra King 40
    By 07vistabluegt in forum MetalWork Discussion
    Last Post: 01-24-2011, 11:27 PM
  4. Replies: 1
    Last Post: 05-29-2009, 07:47 AM
